HP7550 Plus plotter, Programming Manual
08-09-2014, 01:24 PM
Hi.
When HP7550A plotter was released it came along three manual: "Users Guide", "Quick Reference" and "Interfacing and Programming Manual".
Some time after , the "HP7550 Plus" model was released; this plotter was HP-GL2 instead of HP-GL, and had some improvements and a large buffer. The 7550Plus came along two manuals: "Users Guide" and "Computer Information". No "programming" book was included.
Although you can think any HPGL2 reference would do the job, this is not the case because the Plus model has specific commands not found on the HPGL2, and there were some ESC commands not found on the 7550A either.
So my question is: was there a "Programming Manual" specific to the "7550 Plus" (also known as 7550B model) ?
08-12-2014, 04:21 PM
RE: HP7550 Plus plotter, Programming Manual
To my knowledge there was NOT a programmers manual released for the 7550B.
I am not aware of 7550B commands outside of HPGL2; would you please elaborate? Source?
Thank you,
TomC
08-12-2014, 05:30 PM
According to the HP 7550 Plus User's Guide there was an HP-GL/2 Reference Guide and a HP-GL/2 Comparison Guide available.
Dave
10-05-2015, 07:27 AM (This post was last modified: 10-05-2015 02:39 PM by Martin Hepperle.)
Now that I have also obtained such a machine (indeed great machine) I have also checked the accessory list:
HP 7550 Plus
  • 07550-90000 Hardware Support Manual
  • 07550-90001 7550A Interfacing/Programming Manual (for HP-GL programming in 7550A emulation mode only)
  • 07550-60050 Additional fiber-tip transparency pen carousel
  • 07550-50051 Additional fiber-tip paper pen carousel
  • 07550-60052 Roller-ball pen carousel
  • 07550-60053 Liquid-ink drafting pen carousel
  • 33474B 1-Megabyte Memory Board
  • 33475B 2-Megabyte Memory Board
  • 5959-9733 HP-GL/2 Reference Guide
  • 5959-9734 HP-GL/2 Product Comparison Guide
The memory boards seem to be identical to LaserJet III parts. The last two items are not 7550 specific.
Martin
