WP34s firmware update
03-07-2023, 10:25 PM
Hello, I have searched the forum to see if what I'm looking to do has been covered and haven't found any posts about what I would like to do.
I have a WP34S I would like to get the firmware updated. I use to have a cable but can't find it and I also don't have a windows machine. IIRC win95 was needed for the flash software. I built a new machine and got a serial connector for it but I'm guessing that won't work with windows10 and as stated I can't find my cable.
The current version I have is 34S 3.1T 3303 with the timer crystal.
Is there anyone around here that could update the firmware for me. I will gladly pay for the service and the shipping. I would really appreciate it.
Another question is it really needed to update the firmware. were there any big bugs or updates or is the current version I have good enough to get along with.
Also are overlays for the keyboards still available?
Thanks for reading my long winded post(if you made it this far).
Christopher Johnson
03-08-2023, 01:27 AM
RE: WP34s firmware update
https://sourceforge.net/p/wp34s/code/HEA...realbuild/
03-10-2023, 06:04 PM
Thank you for your reply. I know where to get the firmware as I have flashed my device in the past many times. My problem is I have no way to flash the device and I'm am looking for anyone who could flash my device for me. Thanks
03-10-2023, 08:13 PM
(03-07-2023 10:25 PM)cjjohnson Wrote:  Also are overlays for the keyboards still available?
I have 6 sets left. They come two sheets in a set.
However, the ones with “WP34S” top left are finished. The ones I still have, say “WP34C”, look on the photo here: https://cocoon-creations.com/download/IMG_2141.PNG.
Pm if you need.
J
Jaco Mostert, Elec Eng
C47 on DM42, 42S, WP34C&S, 28C, 35S, 32Sii, had 11C; used 67, 85; iOS:42s, Free42, WP31S&34S, HCalc; OSX:WP34C.
03-16-2023, 01:02 PM
Have you found a flashing source?
TomC
(03-07-2023 10:25 PM)cjjohnson Wrote:  Hello, I have searched the forum to see if what I'm looking to do has been covered and haven't found any posts about what I would like to do.
Christopher Johnson
03-19-2023, 04:35 AM
(03-16-2023 01:02 PM)TomC Wrote:  Have you found a flashing source?
Same question. I can update your WP34S using any version available on Sourceforge.
My preference though is for Bit's versions, described here: https://www.hpmuseum.org/forum/thread-2433.html
I don't have any Windows machines either, nor HP's programmer cable. I used a Mac running Ubuntu Linux and Wine with a custom flash programming box I built, adapted from Jebem's instructions, all of which is described here: https://www.hpmuseum.org/forum/thread-25...25975.html
Since then I added a timer circuit to make the Tx / Rx LEDs more noticeable, a simple task that nevertheless doubled the board space.
None of this was easy...
Version history may be found here, although it may not be the best or most comprehensive source: https://www.hpmuseum.org/forum/thread-2476-page-15.html
04-12-2023, 08:47 PM
(03-07-2023 10:25 PM)cjjohnson Wrote:  ...and I also don't have a windows machine. IIRC win95 was needed for the flash software. I built a new machine and got a serial connector for it but I'm guessing that won't work with windows10 and as stated I can't find my cable.
It's been a couple of years since I last flashed mine, but I can say 100% I did all my flashing on a Windows7 machine. I used (originally) a homemade cable and then eventually switched to the genuine official HP cable which a very nice person gave me. It was definitely always Win7, though and worked fine. I have a new(er) laptop now with Win10 but haven't tried on that.
Good luck!
burkhard
12-15-2023, 03:45 PM
[quote='TomC' pid='170186' dateline='1678971752']
TomC
No, I have not. I am now just considering selling the calc as I really never use it.
cjjohnson
12-15-2023, 05:54 PM
Ok. PM me if you are still interested...
12-16-2023, 06:35 PM
I made a cable out of readily available components. The heart of it was a USB to 3v TTL cable from Sparkfun. I flashed my wp34s with it on a Windows 11 PC. Win 10 should be similar. See my detailed description here:
https://www.hpmuseum.org/forum/thread-20668.html
