HP-12C serial number check
03-10-2023, 01:32 AM
Is it possible to decode this serial number to determine the year this HP-12C was made?
PHA7370SWQ
PH I assume means it was manufactured in the Philippines?
Thanks for any help
03-10-2023, 02:24 AM
RE: HP-12C serial number check
According to the following site:
https://serial-number-decoder.com/hp-cal...ulator.htm
This HP calculator was made in China during week 37 of 2007 or 2017
03-10-2023, 02:33 AM
Hi Steve
Thank you for the link, I was not aware of that website.
03-10-2023, 03:59 AM
Philippines,2017,37 weeks
03-10-2023, 04:46 AM
(03-10-2023 02:24 AM)Steve Simpkin Wrote:  According to the following site:
Something definitely went wrong there, because a PH serial number is Philippines, not China. I would assume 2017, since in 2007 I think it would have been made in China.
03-10-2023, 04:57 AM (This post was last modified: 03-10-2023 05:00 AM by HP-12C.)
I did think that a China made unit should always start with a CN serial number, e.g: CN40800888
03-13-2023, 07:30 PM
HP's own warranty check site
There is a web site that will tell you the warranty date for HP products, although sometimes knowing just the serial number is not enough. In that case, you also need a product number, which isn't always obvious.
https://support.hp.com/us-en/check-warranty
In this particular case, I was able to find that this HP 12C was provided with its factory warranty starting 2017-09-19. I had to know a likely "Product" number for this was F2230A.
