Simplify: Minimum vs Maximum
08-16-2023, 01:20 AM
Hey guys. I just discovered the "simplification levels" feature on the CAS mode, and I'm not quiet sure what it does. Could someone explain if possible, please?
Thanks, Batx27 |
08-16-2023, 02:40 AM
(This post was last modified: 08-16-2023 02:43 AM by rprosperi.)
RE: Simplify: Minimum vs Maximum
(08-16-2023 01:20 AM)batx27 Wrote: Hey guys. I just discovered the "simplification levels" feature on the CAS mode, and I'm not quiet sure what it does. Could someone explain if possible, please? You can find the levels defined on p. 51 (PDF p. 101) of the Prime User Guidel. Most folks here are happy to help out if the information is not in the manuals, or a machine does not behave as described (there's plenty of both) but are most helpful for folks that are willing to do a little bit of research on their own before asking, and providing specific questions with specific things tried, unexpected results and what your expected results are. The latest version can be found here: https://literature.hpcalc.org/items/322 --Bob Prosperi |
