Card reader PCB wires by color, why flopped?
01-07-2024, 03:12 AM (This post was last modified: 01-07-2024 03:15 AM by jftman.)
I am looking at two HO67 calculators doing a gummy and clutch check.
I can see at each PCB that the BLUE and ORANGE wires are flopped. When I look closely at the order going into the read/write head they are also not the same from end to end.
I can imagine that inside the head they would be prolly the same connections and they just exit in a slightly different config.
But, the PCB HAS THE ORANGE AND BLUE REVERSED.
Is this a non issue? What makes this OK? Or would it be correct to switch one of them?
Attached File(s) Thumbnail(s)
01-07-2024, 10:40 AM
RE: Card reader PCB wires by color, why flopped?
This is the sketch from Tony Duell's HP-67 circuit.
cheers
Tony
01-07-2024, 04:15 PM
Thankyou Tony.
I will unflop them.
