HP 48GX Insights Program Disk
07-26-2024, 08:29 PM
Does anyone know if this disk is still available. I can't find Larkin Publications other than a UK site. So I don't know if there still in business.
"HP 48GX Insights Part II Programs Disk". William Wickes
Randy
07-28-2024, 01:53 PM
RE: HP 48GX Insights Program Disk
I doubt that this disk is still released.
Anyway, you can find all the books of William C. Wickes here : https://literature.hpcalc.org/#author:Wi....%20Wickes
Some programs related to these books can be found here : https://www.hpcalc.org/search.php?query=wickes
Hope it helps.
Bruno
Sanyo CZ-0124 ⋅ TI-57 ⋅ HP-15C ⋅ Canon X-07 + XP-140 Monitor Card ⋅ HP-41CX ⋅ HP-28S ⋅ HP-50G ⋅ HP-50G
07-28-2024, 08:08 PM
Super
Found it.
Thanks
Randy
08-03-2024, 06:10 PM (This post was last modified: 08-03-2024 06:51 PM by Allen.)
I see the Disk for Volume 1 in the hpcalc archives, but not the disk for Volume II.
Eric should now have a backup copy for the archive. The README file for DISK2 begins as follows:
                         HP 48 INSIGHTS II PROGRAM DISK
                         Version 2.0   August 20, 1992
     This disk contains all of the named programs listed in HP 48 Insights
     Part II, plus many unnamed example programs, equations and data
     arrays. Each of these is contained in a separate ASCII file, named as
     described below, and may be loaded into the HP 48 using the Kermit
     file transfer protocol and a serial cable.  The files may also be
     viewed or modified with any text editor.  Files from chapters 14-17
     are contained in the disk directory CHP14-17; the remainder are in the
     directory CHP18-21.  In addition to the individual ASCII files, the
     disk contains binary files named PART2, CHP14, CHP15, CHP16, CHP17,
     CHP18, CHP19, CHP20, CHP21.  PART2 is a directory object containing
     all of the programs and examples from the disk.  Transferring this
     object into the HP 48 using Kermit binary mode loads all of the disk
     objects in a single operation; the total HP 48 memory size is 20714.
     The PART2 directory contains subdirectories CHP15 - CHP21, each of
     which contains the objects from the corresponding chapter.  Within
     each subdirectory, the objects appear in the VAR menu in the same
     order as they occur in the book.  The separate chapter subdirectories
     are also provided on the disk.
File MD5SUM for all files on disk:
efbbfab5fd975d666add7ed74a67807b *CHP14
08b96dd326ec3aadec0ea974f242d2ff *CHP15
f1f19fe5368feb22dbb989f319eb001c *CHP16
bdf6898b05e40d717cfa111128512a10 *CHP17
03f6dd145a58a6f50655de5795dc7c24 *CHP18
b56a3dd0e0b8ef58b803d8f8817ea1d7 *CHP19
60b014857865f4d5f39bd40ea36ae648 *CHP20
9134cf62f9adfad7b6ffcbd29fd69916 *CHP21
13aee5d36ae716b8eeae3a8568ccf528 *PART2
c7642309dbd14cd520f76d5177e81aa4 *README
CHP14-17: Is a directory
772a39f95731f7e1fa7f17646cbfe80c *COSSUM
cf71880a95883a125e60bb7058d9b3f0 *CSC
9b1c01695c2322071cb6dc829289c45a *CUBEX
738b239171d49b303dcacb2d3771f330 *CUBEX.EQ
d3a7f71bab5b1db3a1e390e758619703 *CUBEX2
cb4719879d141bc43bf6a1694e06a2d4 *D510
934cd8ab959733e36cb4d4e03bbf3092 *DERCSC
f5de36e37d2abe107de2ac577a08f494 *DERSIGN
06df63b43149a8c226416cb26f178d5b *E450
eb171926dd71a5d92063ed54eaf57098 *E479
b731c9f3e83b637e87407197f64c5e72 *E489
bfb505a9700cef3ed59f69276e9ffac3 *E492
ac74dc601b34c23d1c1fa2d519622b62 *E498A
87e41595477bd0e8c0e3294f5dbb0705 *E498B
be7267f64f860869d96488b47e607dec *E501
2595ec79a34c38769d122af0858d3cf1 *ENVEX
576607abfdca2e3d4002f763c6f77da5 *FIG8
a22cd4753b5f89304128c82984718e97 *FLOWER
9d7584a44b23fa81a92f469257d881aa *FXYZ
a3374bc51734c2ac5fffc514bcf22375 *ITDRAW
318857a8ab19187eb9d821ddbe45c32c *JULIA
d8a790f97abec62268fda8aa9db2ae85 *L441.EQ
d4711d6d6d93551a635b002b59c40a31 *LIST.EQ
1d830c66883dd306d91576945809fafc *LPWR
86cfff6dbbf6338aceb8b82516905d8f *MAND.EQ
3a822104d2ee1cb3a68cccfaf058ab94 *MANPLOT
40d1d931fda305f02f37c5b7adaf62cf *P441
008de96a326e18936498340d6d95b8c5 *P462
1259f5453bec138fb10a0cb8a7498b9b *PADD
803e53cfce9211c4d67787e98d38f9ff *PDIVD
66630118561e4819423613c5e8aed42d *PEXPR
26c3ae0a0a0f40e5e542088f79fc56dd *PLIST
e0b0ccc1541043b567e51b6f6a54e04d *PMUL
03652675f97888b2a3f2ac51a2adf268 *PNEG
1afd765f2d4deaf6960d129cc70f00d6 *POLY
c328208d32b596fb8bd8f0316863824b *POLYF
4e7721e65bf636a455c1a415b36399f0 *PPWR
10dbbc8a775ff24c28c1bd5b2471d174 *PREST
b44a674045fcb2aae1caf98e193c146f *PSAVE
f386cbb39c8141e9b4a403ea4113e06b *PSUB
83826552c9262fd280d11f9cfb97e981 *RIDGET
3e9660c1fe8ac35d15a2abf7a46b74fc *RRCAR
f3cf03201639bba09f69d6f8295a2647 *S436
49b83273e4ee73b73627b8319377895d *S504
c3764f0ea75a3828c2faa560ce86a227 *S505
a41d9c391e979317d49febaaa04487df *S512
809c835005a55c3ad5d2d29146152d87 *S513
4e5408c489e8d591034e2fa40c91583c *SCDRAW
3f53655e714b44b99c55532683a5568b *SETTICKS
d6d90bceb982480d4b95dd6a421156c9 *SLVDRAW
e9ebd7be71369d45405101de5da51853 *SPACE
3b4d0811007510fc78bcd185540a948d *SPACE.EQ
8e2fe9f13733a9a01a04a578a1ba606e *SPIRAL
37075cbb89a95a958e7a025e00bb32e7 *TEDDY
ec979bf5db6539ffb031cc53bf5589b3 *TICKAXES
204b3751993397e4eb2c52e1a504ce4d *TOCOSSUM
6c879172640961dc8a33aa9e57aa23ff *TORPN
11ca4e2a88f7b9cf790e7d2e100a1a31 *TRAVEL
6949644025efc6733919e3f61b6e5b38 *TVM.EQ
975686fee4a193e5992e49c48f004565 *VARPAR
6d5b351305f07e993618b40155babd22 *VARPOL
e5045262b0972c7bffcf43389dca235f *XJULIA
0b193bc3b005e6930a41d6bf7c1190f5 *XSPACE.EQ
CHP18-21: Is a directory
c8ed1f23ed5dcda734f6ef1c06093a73 *ADD&T
eed0019335b26959bae8fab4a5d4adb2 *C1ADD1
a11088a2f7abec8ce2cb39f0f0a8bed2 *C1SPLIT
d32987c88a0663b937e846a384be1fd4 *CDIST
d4d9123e19270b034b6e6a9ea48f29d4 *CHIMES
9720ff7751f0afb4aa6201bce96405c9 *CHVAR
5e4214afe594f52bf44fb86a2b045964 *CLADD1
9bd8875c3f02d069c3c0eed83d0946cc *CLSPLIT
e66e9de6cfd6df9d82ded01e17c42d85 *DD&T
cc07455bf51c9af4d87f0b15bb982c7c *DELCHIME
b80524b16675ae008a417914136c8006 *DELOLDAL
2249650232b1d43348154bc1ac7ab3db *DER%T
d01971e2b228cb26c4954ce61cce97eb *DERSEC
7b00ace72950e3ddae1cb409294a232d *DOW
d8745edc9396be5549b0f5c35a2514ee *DRAWEBAR
131857fc0420b77208ce0407132f682d *E618
e7df9f9e5133a5c27cbc7e3cc30fc8c4 *E619
04c226220a366e21b0d9573dc8969a04 *FDER
a23d023b8662825cd4dd5d9d6dad6367 *FDIST
043c222759782569e47e3d854de1ac7c *FUNOF
606059d4ef38998cc994d0173a0ffd23 *FUTPF
3ff6fcde2758fb0c18f9f9b54a012626 *GAMMA
9440aebc98e0c1e49752f2cbac36429f *INDEF
254cbf4bd6c2df16bdfe82a55c9a1188 *INTEVAL
1e7de2452553fd277a013445357719c0 *INTSAMP
39652c91b040c859794cb801b0581cc6 *IPATS
f321f1105b414a36e4425bd6042c4b6d *L619.EQ
1c827d5b4d9263277d9f4148d4316d30 *LINEAR
3fe2981687657048c39ee08b103c49db *LSFIT
8923f6522f3f773842593146982a391b *M642
9116803b5ad5ff1cb3b0efc1b0ae9b6c *M652
229121c78cee911a1fcae7f7f0c88e8b *MEDIAN
05ec5bd46bb8751d867f9f4e1a7b81a3 *MNORM
352abd3eba57915e881b8d457ada8485 *NDIST
37cb9e44c0ba84ad735d2205f2e01d42 *NEXTDAY
97f363aaa23aaed37e772be60979a5d4 *NLFIT
9c220e84cbd14897857751d9356909ae *NORM
f281c0049093049bd8a11b185871266e *NSEGINT
c12d1e73820f0504cd0dc4cb8c3d56b2 *POLYFIT
0f3531955f84ab92ff319ec95b0f5afe *PRGINT
d8540442d2676206522cda5bf37c8507 *S610
e66c59f98beb9bc55b314ac237bbfb14 *S616
30f271db7ce00fee03036b98d6df6188 *S648A
a0742de9c08ce7948862307752cda80f *S648B
18930cdf47c9f37c94a6482305004e8d *S649
e718a13da8235e5f803fcd7ca367def7 *S652
a2ed06a819ed26d776bf5cdbfd1c0187 *S654
96c410c6bda7571cfcba061fab6f630f *S667
906867a9f8480861f8b04aa7d6773ab7 *S668
b3d5fc3cc2332ffeea270fccc3d4f9c6 *S669
fd91199141ce94a57a8468c4c499b870 *S672
9778448aef02b42093ab8ebdb9aeb23e *S683
dbc15878637618dbe64b1125d1658e4f *S687
730e57d43a9c581ffaff859b9215c9bf *S688
946521d3b0ba048421afef5744e4521e *SEC
9fe474b6f3728d67f186b4b5c3fced8b *SEGINT
9507007a0022fb56dec169db7ff2afa6 *SETCHIME
f813a482f1eb769aedb4108ed7dd97b6 *SPATS
09d1905c123b55c002319112c9eac321 *TAYLRX0
63ed8720aa58b45bdd9ad84172410ca6 *TDIST
439484d60654d11c002dc4504b3ad028 *UDIMS
0998f7258a16bf4172cbc64c88de6873 *W660
eeccd6875629623ca4e07e663367a3b3 *X659
a4bebd51048778923f839bd471fdfec7 *X663
90566795d19cb4bfe1adf04c045be315 *X667
76cfeee3b24aab23688c2942ec01d04a *XINT
9f45a73c142bc4e8ca52588458efb038 *XSUM
70cd4adffbb777c7c059f0592eeab552 *Y659
4cbe4b7db0a60821d53fa1b900ed6289 *Y663
af778def6dc6f6f0fbbb44365909b2c4 *Y667
17bii | 32s | 32sii | 41c | 41cv | 41cx | 42s | 48g | 48g+ | 48gx | 50g | 30b
08-03-2024, 06:29 PM
Is there a link yet. I looked in the HP Archive and see Transitions and The Pt 1 disk only.
Randy
08-03-2024, 07:41 PM
(08-03-2024 06:29 PM)knife31 Wrote:  Is there a link yet. I looked in the HP Archive and see Transitions and The Pt 1 disk only.
Randy
A good Eric Question.. I'm sure he has other things on Saturday Smile
08-03-2024, 10:08 PM
I have now added it the listing on the Literature site:
https://literature.hpcalc.org/items/1572
Thanks Allen!
08-13-2024, 01:57 AM
Hi everybody
A belated shoutout to Allen and Eric for delving into the Archives and re-erecting the Program Disks.
Much appreciated
Randy
08-13-2024, 02:46 AM
And if anyone here wishes to have a vhs copy of William Wickes 'Learning About The HP 48', let me know and I'll run a copy for you. It's available on youtube sure, but I tracked down one of of the original video tapes a short while back and still use my vcr to watch plenty of shows.
35 - 45 - 65 - 48sx/gx - xpander - dm42
