HP HP-12C Platinum virtual calculator documentation
08-14-2024, 05:52 PM
(This post was last modified: 08-15-2024 04:45 PM by AnnoyedOne.)
I have three HP "Virtual Calculators" that run on PC's (also Android versions of the first two from 2015). All were found on archive.org.
HP-15C v1.2 29th Nov 2012 HP-12C v1.2 29th Nov 2012 HP-12C Platinum v2.10 10th Dec 2012 The first two are essentially the same. However the last one (HP-12C Platinum) is different. Granted it emulates/simulates the SunPlus 6502 based CPU rather than the HP NUT of the other two (HP-15C/HP-12C) but it also has different menu options. I haven't been able to find any documentation to describe those. Perhaps only on CD supplied with a purchased calculator. Does anyone know anything about this emulator/simulator or have a "manual"? A1 HP-15C (2234A02xxx), HP-16C (2403A02xxx), HP-15C CE (9CJ323-03xxx), HP-20S (2844A16xxx), HP-12C+ (9CJ251) |
