Program for DM32/DM42 clock cal
08-16-2024, 12:33 PM
I wrote a program to generate a clock calibration file for the SwissMicros DM32 and DM42 (maybe others?). Info is at https://udel.edu/~mm/hp/clockCal/ if you'd like to try it. I'd appreciate bug reports but believe it's working. You run it once to start a measurement and after several days run it again to end the measurement, when rtccalib.cfg is created.
I thought it would be only slightly more time to write a program than do the calculations by hand. Several hours later, the program was written and tested. So much for my programming time estimate! :-)
08-17-2024, 09:15 AM
Is It Worth the Time?
[Image: is_it_worth_the_time.png]
08-18-2024, 10:57 AM
RE: Program for DM32/DM42 clock cal
If you look closely, you can see me hanging out in the upper right corner of the graph! :-D
08-23-2024, 01:26 PM
After more testing, I have confidence the program works, but please let me know if you find bugs. I ran it to generate rtccalib.cfg files for my DM41X and DM42. I measured each over about 4 days and the RTCs in each are now keeping good time. -Mike
08-23-2024, 04:38 PM
(08-23-2024 01:26 PM)ab3ap Wrote:  After more testing, I have confidence the program works, but please let me know if you find bugs. I ran it to generate rtccalib.cfg files for my DM41X and DM42. I measured each over about 4 days and the RTCs in each are now keeping good time. -Mike
In saveCalcDate, the setting of timeCalc contains a reference to n.day that probably was intended to be c.day.
The documentation for rtccalib.cfg states that C should be an integer value.
Thank you for writing this and making it available.
Cheers,
Scott
08-23-2024, 05:03 PM
(08-23-2024 04:38 PM)SAllendorf Wrote:  In saveCalcDate, the setting of timeCalc contains a reference to n.day that probably was intended to be c.day.
Cheers,
Scott
You're welcome, Scott, and thanks very much for catching those bugs! Now fixed, retesting underway.
I had changed some variable names and was certain it was so straightforward that no testing was needed... :-o Also, I completely overlooked that C must be integer - fixed that - yet it seems to work on my calcs and even shows up as a float on the Time Setting screen.
Thanks again,
Mike
