Mixing input and output in a Prime program
09-22-2024, 10:25 PM
(This post was last modified: 09-22-2024 10:25 PM by CheshireChris.)
I'm trying to get my head around the basic ideas of Prime programming in PPL, and there's one thing I'd appreciate some assistance with.
In a typical "command line/terminal" program you might want to display some information to the user, prompt for an input, and then display some further information as a result To use a trivial example of a card game, something like: Your cards are 5 7 J K A How much do you want to bet? And then wait for the user to type in a number. On the Prime, information output with a "PRINT" command goes to a terminal screen, but when you prompt for an input, this is done on a separate "input" screen and the terminal is hidden. How can you display information to the user and then prompt for an input with that information still visible? Chris |
09-23-2024, 01:34 AM
RE: Mixing input and output in a Prime program
You can put Your cards are 5 7 J K A in the title of the input window.
09-23-2024, 05:02 AM
(This post was last modified: 09-23-2024 05:02 AM by komame.)
(09-22-2024 10:25 PM)CheshireChris Wrote: On the Prime, information output with a "PRINT" command goes to a terminal Besides the INPUT command, there is also the READLINE command, which allows the user to input in a separate line at the very bottom of the terminal screen. This way, the terminal is not hidden. Code: EXPORT USERINPUT() The READLINE command returns a string, so in your case, you need to convert the input to an integer. Piotr Kowalewski |
09-23-2024, 06:03 AM
(09-23-2024 05:02 AM)komame Wrote: Besides the INPUT command, there is also the READLINE command, which allows the user to input in a separate line at the very bottom of the terminal screen. This way, the terminal is not hidden. Perfect! Thank you - this is exactly what I was looking for. Chris |
09-23-2024, 11:56 AM
(09-23-2024 05:02 AM)komame Wrote: The READLINE command returns a string, so in your case, you need to convert the input to an integer. Another very simple question: the only type conversion function I can find in PPL is "EXPR". Is this the correct function to use to convert a string to a number? Something like: Code:
Chris |
09-23-2024, 05:49 PM
Bonjour
Oui c'est bien la fonction EXPR qu'il faut utiliser. Attention EXPR fonctionnera seulement si vôtre entrée est une valeur uniquement : EXPR("128.5") --> 128.5 EXPR("128.5$") --> erreur Contrairement à VAL( des anciens Basics . Hello Yes, you need to use the EXPR function. EXPR will only work if your input is a value: EXPR("128.5") --> 128.5 EXPR("128.5$") --> error Unlike VAL( in the old Basics . Sorry for my english |
09-23-2024, 05:53 PM
(09-23-2024 05:49 PM)Tyann Wrote: Hello Merci, Tyann! Chris |
