(HP 41 or 71B) Transfer data on cassette-drive into virtual drive: HowTo?
10-26-2024, 10:14 PM
during Stuttgart 2024, the question was asked how to copy data in a cassette into a virtual drive (on a PC or PI ).
Before I get the cassette drive and connect it with a pilbox in a loop (connected to a PC or raspberry PI) and an HP71B, can I get here a feedback if it will work?
I think of..
CAT :1 (in the basic prompt) -> will show the programs/data AA BB CC.. XX of the cassette drive (assuming it is the first in the loop)
I will have to find the address of the virtual drive in the loop (behind the pilbox): lets assume it will be :2
Then the copy should be COPY AA:1 TO :2
then .. BB .. CC.. all files
Any advice is welcomed if it could work before I start to gather the hardware.
HP71B 4TH/ASM/Multimod, HP41CV/X/Y & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X
10-26-2024, 11:45 PM
RE: (HP 41 or 71B) Transfer data on cassette-drive into virtual drive: HowTo?
For the HP-41 see the Mass Storage Operations section in the Extended I/O Module Owner's Manual.
Try CC41!
10-26-2024, 11:51 PM (This post was last modified: 10-26-2024 11:56 PM by Dave Frederickson.)
Can you connect the tape drive to a PIL-Box and to Emu71 through ILPer?
Then COPY file:3 TO :2
where :2 is the default virtual drive and the tape drive is after the PIL-Box at :3.
10-27-2024, 12:16 AM
(10-26-2024 11:51 PM)Dave Frederickson Wrote:  Can you connect the tape drive to a PIL-Box and to Emu71 through ILPer?
EDIT: I now recall a LEX file that will copy all the files from a tape to a virtual disc. I did this for Bob about ten years ago. The LEX file was called MCOPY, but since then Sylvain developed a program called TAPEDUMP that reads the tape sector by sector.
https://hpmuseum.org/forum/thread-16513-...#pid144808
10-27-2024, 02:19 AM (This post was last modified: 10-27-2024 12:14 PM by rprosperi.)
Yes, the MCOPY LEX file works fine in general, one just uses the command
COPY : S TO : D (with no spaces between : and letters - added here to prevent emojis.... <sigh>)
where S is the source drive ID and D is the destination drive ID. There are warnings in some old notes (somewhere...) that warned that having the ROMCOPY LEX file installed could affect how the MCOPY LEX works, but I never encountered the problem. That said, I have only copied 4-5 tapes this way, so I can't really say it's bullet-proof or well-tested, rather that casual use did not reveal any problems.
Sylvain's program is quite extraordinary, but that was intended for extracting data from a tape that was written using non-standard equipment, so more of low-level byte-by-byte data grabber than media copying utility.
10-27-2024, 03:16 AM
Do I need the EMOJI LEX file to be able to enter those commands? Wink
My Collection: 55, 67T, 25PLP, 34C, 15C, 16C, 41CV, 41CX, 41-CL, DM41X, DM42, 42S, 48G, 71B, 75C, 95LX, HP-150, Portable+, HP-86, Integral PC.
10-27-2024, 06:31 AM
(10-27-2024 03:16 AM)twoweims Wrote:  My Collection: ... HP-150, Portable+, HP-86, Integral PC.
Are they all HP-IL equipped ? (the Portable+ is of course)
J-F
10-27-2024, 06:41 AM
(10-26-2024 10:14 PM)floppy Wrote:  during Stuttgart 2024, the question was asked how to copy data in a cassette into a virtual drive (on a PC or PI ).
My ILvlif program (on my site) can make an image to a PC file using the PIL-Box.
My site says that ILvlif has not been tested with the cassette drive, but it has since been successfully used in that way.
J-F
10-27-2024, 07:42 PM
Don't forget to replace the pressure pads on the cassettes. To save some work, you can replace the pad on just one spring and then use that spring/pad on subsequent tapes.
10-28-2024, 04:21 PM
(10-27-2024 07:42 PM)Dave Frederickson Wrote:  Don't forget to replace the pressure pads on the cassettes. To save some work, you can replace the pad on just one spring and then use that spring/pad on subsequent tapes.
I never had a cassette in my hands. Can you elaborate your thoughts with pictures?
Then when I will get the drive and the cassette, I will know what to do.
10-28-2024, 05:06 PM (This post was last modified: 10-28-2024 05:12 PM by Dave Frederickson.)
Look here.
https://www.hpmuseum.org/forum/thread-21...#pid184811
Here's Tony Duell's tape repair guide.
https://www.hpmuseum.org/guest/duell/rep82176.pdf
Here's a pic of some repaired tapes. Sorry it's a download. I can't seem to be able to insert pics anymore.
https://drive.google.com/uc?export=downl...s68oi95YOy
Dave
