Report a bug in Geometry App.
11-11-2024, 07:45 PM (This post was last modified: 11-11-2024 08:04 PM by amindanial.)
In Geometry App., whenever the Symb view is opened and there is any function or element to be plotted is inserted, as shown in the following image, if I sweep my finger on the screen from right to left or vice versa, the calculator reboots.
The software version is:
11-11-2024, 09:13 PM
RE: Report a bug in Geometry App.
I have an HP Prime G1 calculator (same software version) and I tried to do this. It works fine for me, the calculator does not reset. Try resetting your calculator. Insert a paper clip into the hole on the back of the calculator that says "Reset" and press. After resetting, go to the Geometry Symbolic View page and re-enter the point command (1,2) and then go to the Plot page and see if it is OK now.
11-12-2024, 06:35 AM
Confirmed on my G2 running the same version of the software and the point defined is lost.
Tested subsequently on a Rev. C G1 running the 2024-07-21 beta software: OK
Updated the Rev. C G1 to the latest version: OK
This definitely looks like a problem specific to the G2.
Current daily drivers: HP-41CL, HP-15C, HP-16C
11-12-2024, 01:26 PM
How can we report such bugs to the company to be fixed in future firmware?
11-12-2024, 02:09 PM (This post was last modified: 11-12-2024 02:29 PM by RPNerd.)
I'll point Radim to this topic.
Edit: Radim just got back to me. He's forwarding the info to the developer.
