WP-31s: inversion of conversion
11-10-2014, 10:43 AM
I'm currently starting to use the WP-31s. I especially like the design of the overlay, which is arranged very clearly and has all the functionality that I need. (If programming and printer functions were added this would be the perfect calculator, but I understand that this would make the user interface more complex).
Many thanks to all who have made this possible!
I have one question concerning the unit conversion dialog: On the WP-34s it is possible to invert the conversion by pressing [f], and [B] (= 1/x) to change from e.g rad->° to °->rad. Is there a similar funtionality on the WP-31s? I couldn't find any hint in the manual.
Bernd
11-10-2014, 08:18 PM (This post was last modified: 11-10-2014 08:21 PM by walter b.)
RE: WP-31s: inversion of conversion
Inverting survived as described for the WP 34S:
E.g. 4 acres->ha returns 1.619 (ha). Now press f B and you get 9.8842 (acres, equivalent to 4 ha). Press f CONV again to get 4 confirming 9.8842 acres correspond to 4 ha.
Sorry for not mentioning it in the manual.
d:-)
11-11-2014, 07:40 AM (This post was last modified: 11-11-2014 07:45 AM by Bernd Grubert.)
Thanks for the information.
It's a little embarrassing that I have described the procedure and not noticed that it actually works. May be this post helps other users who don't know the WP-34s.
11-11-2014, 05:28 PM
The reasoning behind f+B on the WP 34S was the 1/x label above the key. We should remap the function to f+F on the 31S because the key carries the 1/x label.
Marcus von Cube
Wehrheim, Germany
http://www.mvcsys.de
http://wp34s.sf.net
