Virtual HP Prime Crashing
11-26-2014, 01:38 PM
I'm running the latest version of the virtual HP Prime emulator on Windows 8.1 (64-bit) Nothing happens when I press the EDIT button to edit a program. If I try to delete a program, the app crashes and restarts. The older version never did this. Is there a fix?
TIA
Tom L
Cui bono?
11-26-2014, 01:59 PM
RE: Virtual HP Prime Crashing
Two ways I know of are to
1. Use the reset menu option in the emulator menu
Or
2. Delete the HP Prime data folders located in your app data directory. I don't have windows 8.1 on hand so perhaps someone who does can give the direct path to these folders
Graph 3D | QPI | SolveSys
