Bug with EDITMAT()
12-18-2014, 10:26 AM
(This post was last modified: 12-18-2014 10:40 AM by bobkrohn.)
Bug with EDITMAT()
From Home. on actual calculator
EDITMAT() seems to work with built-in Matrix variables like M1. Try to use a user defined Matrix and you discover a BUG. Locks up the calculator. on Reset you find your user defined Matrix has disappeared. It seems to be OK on Emulator |
12-18-2014, 12:21 PM
(This post was last modified: 12-18-2014 01:26 PM by Snorre.)
RE: Bug with EDITMAT()
Hi Bob,
I couldn't reproduce this behaviour on my device It seems that something's odd with your device. Have you already tried a hard reset (Turn off, then press and hold [Templ]+[Power]+[Comma], then switch on, then release, finally -- in diagnostic mode -- select [9] Reset). Beware, you'll wipe your data (make a backup). [EDIT #2]: Forget about it! First check if your current app is "Spreadsheet" and if your matrix' name collides with a cell's name (maybe it's similiar to this issue). |
12-18-2014, 02:45 PM
(12-18-2014 10:26 AM)bobkrohn Wrote: From Home. on actual calculator Is your firmware up to date? Graph 3D | QPI | SolveSys |
12-19-2014, 05:28 AM
Yes firmware it's up to date. Dec 03 2014 version.
Speadsheet is active but there is nothing in it. I entered numeric data into M1 then Stored to my custom named variabe i.e. M1>KoGo I'll try everything again tomorrow. Had to reset with a pin in the hole on back. |
