HP Prime object types for INPUT command (SOLVED)
03-19-2015, 06:50 PM
(This post was last modified: 03-21-2015 06:43 AM by Spybot.)
Hi Everyone! I'm writing a little program on the HP Prime and I'm using the INPUT command, so I need to know what the object types are: for example: Real number: (object type code?) String: (object type code?) integer: (object type code?) ... etc. where can I find these codes? help please! Spybot. |
03-19-2015, 06:57 PM
(This post was last modified: 03-19-2015 06:59 PM by salvomic.)
RE: HP Prime object types for INPUT command
(03-19-2015 06:50 PM)Spybot Wrote: For use see in the help for INPUT (Toolbox - me -> Catlg, search input, then press Help). (Sure you had already done it)... Then see in this web page and search TYPE. The types are: 0: Real 1: Integer 2: String 3: Complex 4: Matrix 5: Error 6: List 8: Function 9: Unit 14.?: cas object. the fractional part is the cas type ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
03-19-2015, 07:00 PM
(This post was last modified: 03-19-2015 07:02 PM by rprosperi.)
(03-19-2015 06:50 PM)Spybot Wrote: Just use the Prime to find out, e.g. in Home, TYPE(5) [Enter], TYPE(#4), TYPE("abc"), TYPE(5+3i), TYPE({1,2,3}) will give you those types (0, 1, 2, 3 and 6 for these examples) Edit: Clarified this is in Home --Bob Prosperi |
03-19-2015, 07:04 PM
Hi, Salvomic!
Hey... Thanks a lot ! That was really helpful. Spybot. |
03-19-2015, 07:05 PM
(03-19-2015 07:04 PM)Spybot Wrote: Hi, Salvomic! you're welcome! ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
03-19-2015, 07:06 PM
Hi Bob!
That is another approach, nice and clear! Thank you! Spybot. |
03-19-2015, 07:26 PM
(This post was last modified: 11-30-2022 08:28 PM by Spybot.)
_______
Spybot. |
03-19-2015, 07:28 PM
(03-19-2015 07:26 PM)Spybot Wrote: OK.... Is this normal? they are real numbers, so type=0 {1,2,3} is a list -> type = 6 and so on... ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
03-19-2015, 07:31 PM
(This post was last modified: 04-13-2015 04:06 PM by Spybot.)
hp50g used to notice the difference between these.
Than You Salvomic! Spybot. |
03-19-2015, 07:36 PM
(03-19-2015 07:31 PM)Spybot Wrote: hp50g used to notice the difference between these, but now I can see clearly the way HP Prime works. TYPE() and type() are different you're trying in Home... In CAS you get: type(5) = DOM_INT type(5.9) = DOM_FLOAT type(⅔) = DOM_RAT but TYPE(5.9) = 0 also, and so on... ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
