Global Variable
03-20-2015, 06:53 PM
Global Variable
This is a simple test.
Try to fill this EXPORTED var3 with subroutine.
var1 and var2 have values, but var3 keeps on zero.
What is wrong on this?
Cheers,
Jan
TEST(); // Declaration of the subroutine
EXPORT var1,var2,var3; //Exported variable
EXPORT F1 ()
TEST(); // Call TEST and fill var3 with value
INPUT({var1,var2},{"var1=","va2="});
RETURN var1+var2;
TEST()
var3:=12345.6789;
03-21-2015, 02:02 PM (This post was last modified: 03-21-2015 02:54 PM by DrD.)
RE: Global Variable
Changed the INPUT(..) line. This should work:
EXPORT var1:=0,var2:=0,var3:=0; //Exported variable
EXPORT F1 ()
INPUT({{var1,[0],{25,50,0}},{var2,[0],{25,50,1}}});
RETURN var1+var2;
TEST()
var3:=12345.6789;
03-21-2015, 08:23 PM
RE: Global Variable
(03-20-2015 06:53 PM)Powersoft Wrote:  This is a simple test.
Cheers,
Jan
EXPORT F1 ()
RETURN var1+var2;
TEST()
var3:=12345.6789;
Your program works fine on my Prime as is. I get var3 value as assigned.
I have the same firmware and Model as you. Runs fine on both the emulator and
the real Prime.
03-22-2015, 02:30 AM
RE: Global Variable
Cheers,
Jan
EXPORT F1 ()
RETURN var1+var2;
TEST()
var3:=12345.6789;
Check and see if var3 isn't also an already existing variable (prior to creating your program).
Graph 3D | QPI | SolveSys
