PRINT(); command weird behavior.(SOLVED).
03-24-2015, 06:10 PM (This post was last modified: 03-24-2015 06:56 PM by Spybot.)
Hi Everyone!
I have a question about the PRINT(); command.
I don't know why my program is skiping the PRINT(); command...
I have the following code:
EXPORT test()
LOCAL me;OP;
me:="To find the shortest distance between a point and a line, you need to provide one of the following data sets:
1) Ax+By+C=0 & P(x₀,y₀)
2) y=mx+b & P(x₀,y₀)
3) P1(x₁,y₁),P2(x₂,y₂) & P(x₀,y₀).";
PRINT();
PRINT(me);
CHOOSE(OP,"I Have...",{"Ax+By+C=0 & (x₀,y₀)","y=mx+b & P(x₀,y₀)","P1(x₁,y₁),P2(x₂,y₂) & P(x₀,y₀)"});
when I run this code, it jumps right straight to the CHOOSE command, and I never get to see the text.
Any ideas about what could I be doing wrong! I'll appreciate it.
Spybot.
03-24-2015, 06:23 PM
RE: PRINT(); command weird behavior.
(03-24-2015 06:10 PM)Spybot Wrote:
Hi Everyone!
EXPORT test()
LOCAL me;OP;
PRINT();
PRINT(me);
CHOOSE operates on a different graphics buffer than PRINT, if I'm not mistaken. Does it still behave this way if you place a WAIT(-1) in between the PRINT and CHOOSE ?
Graph 3D | QPI | SolveSys
03-24-2015, 06:42 PM
The LOCAL declaration needs a comma separator:
LOCAL me, OP;
Otherwise a wait(-1); for the terminal screen to display me:
EXPORT test()
LOCAL me,OP;
PRINT();
PRINT(me);
wait(-1);
03-24-2015, 06:50 PM
(03-24-2015 06:42 PM)DrD Wrote:  The LOCAL declaration needs a comma separator:
LOCAL me, OP;
yes, in fact.
I was writing the same thing Wink
it should be the comma...
salvo
03-24-2015, 06:56 PM
Thank you very much Guys!
Very valuable answers!!!
Spybot.
