Gallery: The HP Prime PNG/JPG Image Viewer [UPDATED V2.3.0 07-08-17]
05-18-2015, 03:09 PM
(This post was last modified: 08-07-2017 10:49 PM by mandresve.)
Hello everyone. For some time my interest has turned to visualize images in the HP Prime... and finally here, the liberty from the Websites or others conversion tools!!
This application called "Gallery" offers the ability to view PNG and JPG files natively and directly into the calculator. Just follow the instructions to make the program work. How to install this app:
TIP: Compress PNG or JPG before upload is a good idea. Click to Compress Here! TIP: Pictures with 320*240 of size and 8 bit bit-depht works better. TIP: Any Image Size is supported. How to use this app:
UPDATES (07-08-17):
Changelog: (18-05-15) v1.0.0. Initial Release (19-05-15) v.1.0.2. Added: Zoom feature with Keyboard Added: Multi-Image Browsing Improved: Stability (19-05-15) v.1.0.6. Added: Move feature with Keyboard Improved: Stability, Resolution Capabilities, App Size. (24-05-15) v.1.1.3. Added: Move feature with Touchscreen, Invert Color, Panic Button. Improved: Zoom, Stability, Resolution Capabilities, Velocity, App Size. (23-06-15) v.2.0.0. Fixed version to run in 8151 (17-06-15) Firmware. Added: Zoom feature with Touchscreen. Improved: Zoom, Stability, Velocity, App Size. (21-04-16) v.2.1.0. JPG/PNG File support under 10077 Firmware! Capable to run in 10077 Firmware Improved App Size and Stability Improved App Speed Improved RAM Memory Management Improved File Transfer New Icon and Samples (07-08-17) v.2.3.0. JPG/PNG File support under 10077 or newer Firmware! Improved App size and stability Less loading time and no flickering Improved file transfer New Functions like "Go To Page" and display the file name. Please send me a message on the HP forums or email me at: mandresve@hotmail.com Thanks! Download: NEW V2.3.0: ![]() (+1737 Previous Downloads) Screenshots: Success is the ability to go from one failure to the next without any loss of enthusiasm. View PNG/JPG in your Prime |
05-18-2015, 03:20 PM
RE: Gallery: The HP Prime PNG Image Viewer
(05-18-2015 03:09 PM)mandresve Wrote: Hello everyone. For some time my interest has turned to visualize images in the HP Prime. When the firmware was released 7820 we have been able to use the new features in favor of creating an application that can display image files on the calculator. Very impressive, Manuel! thanks a lot, gracias. Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
05-18-2015, 03:35 PM
(05-18-2015 03:20 PM)salvomic Wrote: Very impressive, Manuel! It was with great pleasure. ![]() Con gusto. Success is the ability to go from one failure to the next without any loss of enthusiasm. View PNG/JPG in your Prime |
05-18-2015, 03:43 PM
Good work !
http://mic.nic.free.fr - Youtube - Facebook |
05-18-2015, 03:52 PM
Muy buen trabajo Manuel! Gracias por compartirlo.
Un abrazo. Very good job, Manuel! Thanks for sharing. |
05-18-2015, 04:00 PM
Hello mandresve!
I've tried to upload a couple of .png images into the "files" folder of your App and it is not accepting any of them. they are: 320 x 240 pixels. as you recommend. Spybot. |
05-18-2015, 04:01 PM
How can you directly run a program by launching the app ?
05-18-2015, 04:10 PM
(05-18-2015 04:00 PM)Spybot Wrote: Hello mandresve! Hi Spybot, Try to Right Click on the "Files" folder inside Gallery, then select "Add File". Press "Save" on the Connectivity Kit and check again. Success is the ability to go from one failure to the next without any loss of enthusiasm. View PNG/JPG in your Prime |
05-18-2015, 04:12 PM
Well done mandresve!
Unfortunately the test image I added in the CK just got stuck in the tree and didn't show up on the calc. Could not delete image from tree and had to remove entire app branch to remove the failed image. Still promising for further enhancements and features. |
05-18-2015, 04:17 PM
(05-18-2015 04:12 PM)petaks01 Wrote: Still promising for further enhancements and features. Of course it will, I am committed to the development of Gallery until the end. At the moment I'm a little busy with my studies (meaning "a little" as much, lol), but I try to provide regular updates. Thanks for the support to everyone. ![]() Success is the ability to go from one failure to the next without any loss of enthusiasm. View PNG/JPG in your Prime |
05-18-2015, 04:20 PM
I've created my .hpappprgm but it doesn't appear in my program list on the emulator
![]() http://mic.nic.free.fr - Youtube - Facebook |
05-18-2015, 04:22 PM
(05-18-2015 04:12 PM)petaks01 Wrote: Unfortunately the test image I added in the CK just got stuck in the tree and didn't show up on the calc. Could not delete image from tree and had to remove entire app branch to remove the failed image. When you add a file in the connkit it doesn't automatically save it to the calc. I didn't want it to try sending the whole app every time you added a file. At the moment, you need to open the app editor, make a text change somewhere which will flag the app as needing a "Save". Then when you hit save it will send the app. If you didn't tweak the app data at all, your files weren't sent along and nothing happened when you hit save. TW Although I work for HP, the views and opinions I post here are my own. |
05-18-2015, 11:44 PM
(This post was last modified: 04-21-2016 10:31 PM by Spybot.)
RE: Gallery: The HP Prime PNG Image Viewer [UPDATED V1.0.2]
I finally got to see my images in your App... It is cool.... much more stable.
Congratulations mandresve. When using the emulator, I also think you should tell people to remember to right-click the Gallery App and send it to Class, after uploading their images. This cost me a bit of time to figure it out. Spybot. |
05-19-2015, 12:05 AM
(This post was last modified: 05-19-2015 12:06 AM by mandresve.)
(05-18-2015 11:44 PM)Spybot Wrote: Remember to right-click the Gallery App and send it to Class after uploading their images. Oh Spybot, thank you! Your suggestion is very important, added. Success is the ability to go from one failure to the next without any loss of enthusiasm. View PNG/JPG in your Prime |
05-19-2015, 04:31 AM
(This post was last modified: 05-19-2015 04:32 AM by mandresve.)
RE: Gallery: The HP Prime PNG Image Viewer [UPDATED V1.0.6 19-05-15]
UPDATES (19-05-15):
Changelog: (19-05-15) v.1.0.6. Added: Move feature with Keyboard Improved: Stability, Resolution Capabilities. Working in the Touchpad Gestures. If someone wants to collaborate, please send me a message on the HP forums or email me at: manuel.velez@uptc.edu.co. Thanks! Download in the first post of this thread! If you like my work, let me know and share the information. Sorry for so many changes from one day to another, but I think worth it! ![]() Success is the ability to go from one failure to the next without any loss of enthusiasm. View PNG/JPG in your Prime |
05-19-2015, 06:15 AM
RE: Gallery: The HP Prime PNG Image Viewer [UPDATED V1.0.6 19-05-15] | |||
05-19-2015, 06:40 AM
Wow, after a good nights sleep I wake up to a useful version and will actually use it today to view saved screens from my DSO.
Big thumbs up! |
05-19-2015, 08:11 PM
(05-19-2015 06:40 AM)petaks01 Wrote: Big thumbs up! Many Thanks to all for the support. I'm receiving any type of suggestions... Greetings from Colombia. Success is the ability to go from one failure to the next without any loss of enthusiasm. View PNG/JPG in your Prime |
05-19-2015, 08:18 PM
It would be nice to view icons as actual size images. Using the zoom (+/-) buttons causes the icon image aspect ratio to distort when zooming out.
05-19-2015, 08:52 PM
(This post was last modified: 05-19-2015 08:54 PM by mandresve.)
(05-19-2015 08:18 PM)John Colvin Wrote: It would be nice to view icons as actual size images. Using the zoom (+/-) buttons causes the icon image aspect ratio to distort when zooming out. Hi John, Thanks for the suggestion. Currently I'm working in image transformations to detect edges and select automatically aspect ratios (to avoid aberrations) because for now in the V1.0.6, aspect ratios are configured to be multipliers or divisors of 320*240 (Native Prime Screen Resolution). It will be available soon. ![]() Success is the ability to go from one failure to the next without any loss of enthusiasm. View PNG/JPG in your Prime |
