Needing help with infrared printer
05-21-2015, 01:40 AM
Hello. I am in the process of selling a ton of graphic calculators from a friend's estate. I admittedly have almost no idea what I'm doing, but I am trying to make as much as I can for her and her little boy.
This is the printer that was among the things I have been asked to sell:
http://i.ebayimg.com/00/s/MTIwMFgxNjAw/z...36;_57.JPG
and the back: http://i.ebayimg.com/00/s/MTYwMFg4NzA=/z...36;_57.JPG
When plugged in and turned on, it powers up and the red light glows. But that's about the end of my understanding of it.
The calculators I have on hand to potentially use to test it are:
HP 49G+
HP 49GX
TI TI-81
HP 50G
HP 49G
Any help is greatly appreciated, thank you!
05-21-2015, 03:40 AM (This post was last modified: 05-21-2015 03:54 AM by PANAMATIK.)
RE: Needing help with infrared printer
Your printer model is the HP82240B.
http://www.keesvandersanden.nl/calculators/hp82240.php
The HP50G has an infrared port and can be used for testing. See the HP50G users manual page 834.
http://support.hp.com/us-en/product/HP-5...4/manuals/
Just place the calculator in front of the red LED and issue a print command.
Bernhard
05-21-2015, 12:37 PM
By the way, the cables in your auction are not for the printer. I don't think it has any connectors expect for the AC power adapter.
05-21-2015, 02:50 PM
(05-21-2015 03:40 AM)PANAMATIK Wrote:  Your printer model is the HP82240B.
Bernhard
Thanks! Will look into this!
(05-21-2015 12:37 PM)everettr Wrote:  By the way, the cables in your auction are not for the printer. I don't think it has any connectors expect for the AC power adapter.
I'm sure they don't go with the printer, but rather than try to sell them individually I thought I'd make a lot out of the accessories, so to speak. Smile And you're correct, just an AC outlet.
05-21-2015, 03:10 PM
The printer's self test can be run by holding the paper advance button down, turning on power, then releasing the paper advance button. Here's an example printout.
