FRAM71 Ticking Like a Time Bomb
08-21-2015, 09:40 AM
Following Dave's new thread I started my 71 with FRAM71 to play around with the settings.
Now I get a ticking noise from the device. Any idea what that means?
Marcus von Cube
Wehrheim, Germany
http://www.mvcsys.de
http://wp34s.sf.net
08-21-2015, 12:36 PM
RE: FRAM71 Ticking Like a Time Bomb
[Image: bomb.jpg]
08-21-2015, 03:42 PM (This post was last modified: 08-21-2015 03:45 PM by Hans Brueggemann.)
(08-21-2015 09:40 AM)Marcus von Cube Wrote:  Following Dave's new thread I started my 71 with FRAM71 to play around with the settings.
i suppose you mean that the beeper is ticking. make sure that jumpers J2 and CN2:x are all properly set. i suggest to do a full reset:
1) turn off your HP-71B.
2) remove all power supplies (charger and / or all batteries.
3) open the card reader bay.
4) with FRAM71 installed, short card reader connector 11 (GND) and card reader connector pin 1 (VDD) with a straightened paper clip for 5 seconds. consult manual, chapter "Board Connectors" if in doubt about location of pins.
5) close card reader bay.
6) apply power.
7) turn HP-71B on, it will most likely show MEMORY LOST.
8) ticking should be gone.
give me a ring if that doesn't help.
hans
11-21-2015, 04:34 PM
case closed. faulty beeper circuitry on HP-71B.
hans
