Waiting for c328740.ssl.cf1.rackcdn.com ...
01-19-2014, 08:23 PM
Does anybody else encounter problems loading the MathJax.js from this site?
Why isn't MathJax used directly?
<script type="text/javascript"
   src="http://cdn.mathjax.org/mathjax/latest/MathJax.js?config=TeX-AMS-MML_HTMLorMML"></script>
01-20-2014, 04:37 AM
RE: Waiting for c328740.ssl.cf1.rackcdn.com ...
It is being used directly:
Quote:When the the MathJax CDN is accessed via the address http://cdn.mathjax.org, data is downloaded over a regular, insecure HTTP connection. This introduces a security risk, since it is possible a hostile 3rd party could intercept the MathJax program data, and replace it. This is sometimes called a man-in-the-middle attack.
To prevent such attacks, it is necessary to access the MathJax CDN over a secure HTTPS connection. This can be done easily by using the following <script> tag instead of the one listed above:
  src="https://c328740.ssl.cf1.rackcdn.com/mathjax/latest/MathJax.js?config=TeX-AMS-MML_HTMLorMML">
</script>
Currently, the Rackspace service used by the MathJax CDN does not support the use of a human-friendly name like cdn.mathjax.org for secure connections; however, the address given above is stable and safe to use.
01-26-2014, 02:31 PM
Another option would be to install a local copy of the script (if the license allows) and run the complete forum over https. The latter would imply that Dave has a signed certificate which might or might not be affordable. It has the added benefit of protecting login information.
Marcus von Cube
Wehrheim, Germany
http://www.mvcsys.de
http://wp34s.sf.net
01-31-2014, 04:11 AM
It could be loaded here but then it has to be maintained here as well. From the response so far, I'm assuming the problem is not widespread.
