ASTRO LAB 4
09-20-2015, 12:17 PM
ASTRO LAB 4
I have installed astro Lab 4 on my Prime.
As I working trough the examples I have tried the example to calculate the
coordinates of the Sun, page 10 of the Word document.
When I run ListNow, this is printing the time of the Prime as in the example.
{2015, 9, 20.58707...} this is ok!
But when I trie to run =>
FromLocalTimeToUniversalTime(ListNow) I get a Error: Syntax Error.
Also when I trie to run =>
FromLocalTimeToUniversalTime({2015,9,20.58701}) I get a Error: Syntax Error.
My setting is the RPN , and the number format is Standard
The only change I have done is using decimal values for the setup!!
Latitude = 51.8319
Longitude = 4.1318
Please need some help with this.
Cheers,
Jan
09-20-2015, 03:11 PM
RE: ASTRO LAB 4
(09-20-2015 12:17 PM)Powersoft Wrote:  I have installed astro Lab 4 on my Prime.
Jan
hi Jan,
here Astro LAb 4 works well.
I think Marcel -for now- has made it checking only for algebraic use, not RPN (also my Astronomy's program is intended -for now- to be used in algebraic mode); please, try if you get errors in algebraic mode also...
Salvo
09-20-2015, 03:24 PM
RE: ASTRO LAB 4
Hi Salvo,
Thanks for this remark. It is working well. Checked with my SPA program.
This is a very high resolution sun position calculator.
Have also downloaded your program Effemeridi. Find a lot of interesting solutions for porting my SPA to the HP Prime. It had it written for my IPad in NSBasic. So the translating/porting will not be a greate job.
When finished it I will put it on the forum.
Cheers,
Jan
09-20-2015, 03:33 PM (This post was last modified: 09-20-2015 03:33 PM by salvomic.)
RE: ASTRO LAB 4
(09-20-2015 03:24 PM)Powersoft Wrote:  Hi Salvo,
yes Jan, a very precise program, following the formulas by Jan Meeus, also fraction of arc seconds!
Quote:Have also downloaded your program Effemeridi.
thank you.
My program is more precise if used in conjunction with Astro Lab, however is also enough precise...
It has only a few instabilities, but Cyrille, Eried and I are investigating about the causes, stay tuned...
Quote: Find a lot of interesting solutions for porting my SPA to the HP Prime. It had it written for my IPad in NSBasic. So the translating/porting will not be a greate job.
well!
welcome also for your program, then!
Salvo
09-20-2015, 03:51 PM
RE: ASTRO LAB 4
Hi Salvo,
In what editor did you write this huge program?
Cheers,
Jan
09-20-2015, 04:08 PM
RE: ASTRO LAB 4
(09-20-2015 03:51 PM)Powersoft Wrote:  Hi Salvo,
I wrote all in Connection Kit.
But at a some point (I don't know exactly when) it was generated a strange error: now if I edit something in the program, my Prime crashes.
We are investigating on this error, mostly...
Salvo
09-20-2015, 09:59 PM (This post was last modified: 09-20-2015 09:59 PM by Marcel.)
RE: ASTRO LAB 4
Hi Jan and Salvomic!
Thank you Salvomic for your response to Jan and thank you Jan for your contribution for developping a great astro program for HP Prime!
Salvomic and I worked all the spring and a part of the summer in that.. This was for me a pleasure...
Marcel
