AFiles problem
10-23-2015, 12:41 AM
AFiles problem
If I store an object such as AFiles ("name") := obj it works fine.
I can then reload it with xyz := AFiles ("name");
Ok. But just using AFiles () produce an empty list {} and not a
list of files as i would have expected.
Now the problem I'm having is that using
AFiles ("aname") where it doesnt exist produces a system error
which breaks the code.
There seems to be no way to determine if
a stored object exists.
Do i really gave to use an error trap just to determine the
existence of a stored object ?
I work with android Prime only for now on my
Galaxy Tab Pro/Note 2
10-23-2015, 04:54 AM
RE: AFiles problem
Bonjour
AFiles() retourne bien la liste des variables crées avec AFiles("nom"),
mais AFiles est liée à l'application active.
Si vous changez d'application, il faut utiliser Application.AFiles()
Espérant vous avoir aidé.
Hello
Afiles () returns the list of well variables created with Afiles ( "name") ,
Afiles but is related to the active application.
If you change your application, you must use Application.AFiles ()
Hoping you have helped.
Sorry for my english
10-23-2015, 11:31 AM
RE: AFiles problem
Yet another bug in android prime.
10-23-2015, 05:22 PM
RE: AFiles problem
I've passed it along...
TW
