object types
11-11-2015, 11:12 PM
object types
Is there any way to distinguish object tyoes in cas/ppl?
using type or CAS.type or TYPE return different cide. That ok but neither will distinguish a symbolic matrix from a list. type ({a,b}) and type ( [ [q b] [t 2] ] ) both return DOM_LIST and TYPE returns 6 (list) The only case is a purely numeric matrix for which TYPE returns 4 but type still returns list. Are lists and vectors and matrices all just lists in cas..?.and are they fully interchangeable. And by the way the help for type refers to 14.7 with the fraction as a cas type. This makes little sense. I work with android Prime only for now on my Galaxy Tab Pro/Note 2 |
11-12-2015, 06:48 AM
RE: object types
Yes, pretty much everything in the CAS is a list internally... There is a sub-type to distinguish things, but it's lists all the way down :-) Home has a more separated system, with it's ups and downs... Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
