Bug: copying standard form numbers to command line in CAS mode
12-02-2015, 02:53 PM
I can't find this bug on the forum (and Tricider won't let me post for some reason):
In CAS mode, calculate 6.63e-34/9.11e-31. Then copy the calculation (the fraction, not the result) back to the command line. The numbers are broken at the exponent "e" character making the expression unsuitable for further use.
Nigel (UK)
12-02-2015, 03:24 PM
RE: Bug: copying standard form numbers to command line in CAS mode
Thanks. I believe this one was already addressed a while back (internally, not in the public release you have), but will put on the list to check and make sure.
TW
12-02-2015, 08:14 PM
(12-02-2015 03:24 PM)Tim Wessman Wrote:  Hello,
Thank you, Tim. Keep up the good work! It is all very much appreciated.
Nigel (UK)
