documents in the Prime
01-07-2016, 10:23 PM
hi,
a user of another forum asked to me if it's possible to store in the Prime documents (doc, docx, txt) and read it with no issues in their own filetype, i.e. in Notes, Gallery... If yes, what's the greatest size for a such file? thank you, Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
01-08-2016, 05:24 AM
RE: documents in the Prime
You could create an app that would read these files, but none exists at this point. .txt would be relatively easy, but doc files are unlikely. Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
01-08-2016, 07:43 AM
(01-08-2016 05:24 AM)cyrille de brébisson Wrote: Hello, thanks a lot, Cyrille! I'll refer to the user. Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
01-08-2016, 03:22 PM
I'd like to point out that a .doc or any such pretty text document is a binary. And you need a program like word to open read them.
-Luis- |
01-09-2016, 07:27 AM
(01-08-2016 05:24 AM)cyrille de brébisson Wrote: Hello, He podido enviar un archivo .txt guardándolo con codificación Unicode y cambiando la extensión a .hpnote, la calculadora parece no tener problemas en la lectura pero agrega un caracter extraño al inicio del documento. Viga C | TD | FB |
01-09-2016, 09:05 AM
(01-09-2016 07:27 AM)Carlos295pz Wrote: He podido enviar un archivo .txt guardándolo con codificación Unicode y cambiando la extensión a .hpnote, la calculadora parece no tener problemas en la lectura pero agrega un caracter extraño al inicio del documento.hi Carlos, what strange character is it? Have you tried also with a doc conversion? Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
01-09-2016, 08:25 PM
(This post was last modified: 01-09-2016 08:28 PM by jrozsas.)
I use the Windows Notepad and save as .hpnote and UNICODE
The character that appears in the row start causes no problems and can easily delete Leo |
01-09-2016, 08:40 PM
(01-09-2016 09:05 AM)salvomic Wrote: what strange character is it? I'm pretty sure this is the "byte order mark" which helps identify the endianess (16 bit byte ordering) of the rest of the file. There should be editors which allow to save in UTF-16 format without the byte order mark. Marcus von Cube Wehrheim, Germany http://www.mvcsys.de http://wp34s.sf.net http://mvcsys.de/doc/basic-compare.html |
01-09-2016, 08:52 PM
(01-09-2016 08:40 PM)Marcus von Cube Wrote: I'm pretty sure this is the "byte order mark" which helps identify the endianess (16 bit byte ordering) of the rest of the file. There should be editors which allow to save in UTF-16 format without the byte order mark. it's interesting, thank you. However that character is not a problem... The problem for the user is to save his doc(x), that are binaries... I already told him to use only txt... Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
