Problem with negative numbers for INPUT function
02-16-2016, 07:19 PM
I have just registered so I apologize for not being familiar with your procedures. I purchased a wireless Prime directly from HP late December. Currently I am having a problem with a simple Mandelbrot program . I use INPUT to enter data including the x and y centres for the region of interest. I supply default values one of which is negative . If I run the program without editing the negative value , it runs as expected . if I enter any negative value ,including an exact copy of the negative default, then an Invalid Input error message is displayed. I will attach a copy of the program. I would be pleased to hear from anyone who can point out what is causing this behaviour. I should note that I have experienced difficulty obtaining documentation on the Prime,for example I have not found an example of using INPUT for multiple lines of data . Thanks in advance UncleJohn [attachment=3130][attachment=3130][attachment=3130][attachment=3130][attachment=3130][attachment=3130] |
02-16-2016, 07:36 PM
RE: Problem with negative numbers for INPUT function
This is a bug with the Input command. When editing the input value, single quotes are placed around the new entry causing the error message. Entering the new negative value without quotes works correctly without any errors.
02-16-2016, 09:05 PM
(02-16-2016 07:19 PM)UncleJohn Wrote: I have not found an example of using INPUT for multiple lines of data .Have you checked the on calculator help text? Code:
Maybe this helps? Cheers, Terje |
02-17-2016, 02:55 PM
UncleJohn
please more examples, option 1 and 2 is easy but how use checkbox and radio group |
