Wanted: HP-46 or 81 Printer
03-19-2016, 06:39 PM
I have a bad plastic gear in my unit. Renders the printer unusable.
Also used in: Monroe 1330 Compucorp Model 325 Shinshu Seiki type 102 Epson model 102 May need to make one from scratch. |
05-17-2016, 06:26 AM
(This post was last modified: 05-17-2016 06:28 AM by Duane Hess.)
RE: Wanted: HP-46 or 81 Printer
Please let me know if you find anything.
I assume the gear for the EP-102 is module 0.4 with 17/68 teeth, 3mm bore, 7mm total thickness, large outger gear 3mm thick. I'm contemplating getting two separate gears (spur gears w/o hub) and epoxying them together. However, the smallest bore that I've located for the larger gear is 4mm. Can't seem to find a 4mm OD/3mm ID bushing. thanks ** i.e. if you find a gear source that is. (unless you find a surplus pile of EP-102 printers!) |
05-17-2016, 08:11 AM
I know a german seller who might be able to help you guys out. He sells gears and small metal bushings to put together two gears into one double-gear. Example:
Use this gear: http://www.steingraeber-modelle.de/Zahnr...05868_4207 With this gear: http://www.steingraeber-modelle.de/Zahnr...01217_4208 And this bushing: http://www.steingraeber-modelle.de/Einst...01303_4210 To make a double gear with 17/68 teeth, module 0.5 for the inner, 0.4 for the outer gear, 6.5mm total thickness, 3mm bore. If you have a source for the gears alone, you might ask them for the bushings only. At the bottom of the site there is a link to the english version - i dont know where they ship though (and where you are located). |
05-17-2016, 09:52 PM
(05-17-2016 08:11 AM)damaltor Wrote: I know a german seller who might be able to help you guys out. He sells gears and small metal bushings to put together two gears into one double-gear. Thank you for the info. The bushing appears to "fill the bill"! Maybe require minor filing (length), but no big deal. A module 0.5 likely will not "mesh" with a 0.4 gear. The 17-tooth gear undoubtedly turns another mod 0.4 gear (drum axle). Mis-matches typically "chew" each other up. That being said I'll remeasure all the gears to make sure I haven't messed up. None the less, thank you for the bushing post, it appears to be what I need. -- thank you. |
05-18-2016, 05:57 AM
(This post was last modified: 05-18-2016 06:00 AM by damaltor.)
Sure! You also might just email them and ask for a 17/0.4 gear. maybe they have something like that too. Alternatively, without having seen the inners of your printer, you might be able to replace the gear which is connected to the 17-gear by another new gear, which then also has mod 0.5 - that would need one more replacement step, but would bring you a new gear which will then hopefully live longer than replacing only one of the two cennected gears. I dont know if that is possible though.
