Program fails with new firmware, no CAS function.
04-23-2016, 02:18 PM
To aid learning the programming on this beast I have been playing with anothers program. All was fine before the update, now I instantly get "Bad argument type" and 'info' shows the following segment....
while int > 0 do rem := irem(int,10); string := IntToChar(rem) + string ; int := (int - rem)/10; end; Any clues as to why this now fails ?. No sign of the CAS function (as mentioned by Tim) anywhere in the whole program. Regards |
04-23-2016, 02:50 PM
(This post was last modified: 04-23-2016 02:51 PM by DrD.)
RE: Program fails with new firmware, no CAS function.
"int", "rem", and "string" are reserved words. Variable names are important.
04-23-2016, 09:04 PM
RE: Program fails with new firmware, no CAS function. | |||
04-23-2016, 10:33 PM
More strict enforcement of the rules, in an attempt to prevent ambiguous results, I would guess. The evolution of this firmware version seems to have corrected a lot of things, not to mention new features. This is most likely one of the consequences.
