another BUG [ .^ ]
02-11-2014, 02:56 AM
(This post was last modified: 02-11-2014 03:03 AM by churichuro.)
another BUG [ .^ ]
Hello every world!, my first post
don´t talk English, so be kind. the Problem: in home in HP PRIME do: any matrix or vector like [ 2 6 4 ] then try to do .^3 and I get this : [ 6 18 12 ] <--- wrong!!! I must have this answer: [ 8 216 64] the .^ work like .* then is an error please report this error, because is really ugly ! P.D. in CAS this work right. or in home with this form CAS([2 6 4].^3) |
02-11-2014, 04:12 AM
RE: another BUG [ .^ ]
I can confirm this, happens in my prime too.
My website: ried.cl |
02-11-2014, 12:18 PM
(02-11-2014 02:56 AM)churichuro Wrote: Hello every world!, my first post In CAS is OK but in HOME the result i wrong. |
02-11-2014, 01:05 PM
Sorry, but I don't understand. The correct shouldn't be {2 4 6} ^ 3? In this case, the home results in { 8 216 64}.
Marcelo |
02-11-2014, 01:19 PM
Sorry, I had missed the point in command "^ '. Indeed, this is new to me, and normally I would use lists for this type of operation.
Marcelo |
02-11-2014, 09:09 PM
This might be an alternative/workaround for the time being (Home view, but also in CAS):
[2 4 6].^[3 3 3] returns [8 64 216]. Element-by-element operation, kind of like HADAMARD on the HP 50G. |
02-11-2014, 10:59 PM
(02-11-2014 09:09 PM)Helge Gabert Wrote: This might be an alternative/workaround for the time being (Home view, but also in CAS): very interesting Helge, but this work only if you know the number of elements in the vector |
02-12-2014, 12:27 AM
Yes, but that is easy: just use SIZE() and then you know the length of the second vector to be filled with the constant.
Actually, I believe that element-by-element operations are the idea behind the ./ .+ .- .* .^ operators - - so that is how it appears to be designed. What you attempted to do is a shortcut - - and I agree, it is a shortcut that makes sense and should also work in Home - - and it works in CAS, as we know! Of course, you can always change your vector to a list and do this in Home: {2,4,6}^3 returns the correct answer. |
02-12-2014, 05:47 PM
I have a problem with this element by element operations. OK, for matrix multiplication and power it makes sense. For vectors you have dot and cross products, but what is the meaning [1,2,3,4,5]^3 or {1,2,3,4,5}^3? It only makes sense if each element is raised to the 3rd power. IMHO [1,2,3,4,5]^3 should be the standard unless you do that on matrix then you need [[]].^(number).
