hp-calculator in TV-Show
07-03-2016, 07:20 PM
I just found an appearance of a hp pocket calculator in german TV-Show
https://www.youtube.com/watch?v=ArK16XS9Dac
The talkshow is quite old (about the 80's last centurry), the calculator could be a 41?
I couldn't resist and programmed the problem discussed in the show using my HP Prime.
Greetings
07-03-2016, 07:58 PM
RE: hp-calculator in TV-Show
(07-03-2016 07:20 PM)ThomasA Wrote:  the calculator could be a 41?
Yes, definitely a 41.
Greetings,
    Massimo
07-03-2016, 08:22 PM
(07-03-2016 07:20 PM)ThomasA Wrote:  The talkshow is quite old (about the 80's last centurry)
According to Wikipedia the show was originally broadcast on 13 May 1982.
Zapping through the video I only noticed a 41 case on the table. Could you say where exactly the calculator is visible (minutes, seconds)? You can even link to the exact position within the video.
Dieter
07-03-2016, 08:50 PM (This post was last modified: 07-03-2016 08:52 PM by Massimo Gnerucci.)
Dieter
Look @ 10:58-11:00
Greetings,
    Massimo
07-03-2016, 09:07 PM (This post was last modified: 07-03-2016 09:08 PM by Dieter.)
(07-03-2016 08:50 PM)Massimo Gnerucci Wrote:  Look @ 10:58-11:00
Ah, thank you. The 41 already appears about half a minute earlier.
Link to this position: https://www.youtube.com/watch?v=ArK16XS9Dac#t=625.
The parameter "t=625" takes you directly to the 625th second, i.e. 10'25".
Dieter
