CAS: REDUNDANT PARENTHESES
08-26-2016, 11:57 AM
Hello, I would like in future versions, a better and more expert decoder of math expressions, the hp-prime CAS adds unnecessary parenthesis =(
Example #1
Entry line
_________________________________
solve( (x+5)*e^x = (x+5)*e^(2*x), x ) [ENTER]
returns to the history as
solve( ( (x+5)*e^x ) = ( (x+5)*e^(2*x) ) , x )
many people might like it show Extra parentheses, by a flag I would like to disable this feature.
When copying expressions, hp-prime to a document. there always makes editing, the idea is to be nearest to the notation of a math book
08-26-2016, 05:56 PM
RE: CAS: REDUNDANT PARENTHESES
(08-26-2016 11:57 AM)compsystems Wrote:  Hello, I would like in future versions, a better and more expert decoder of math expressions, the hp-prime CAS adds unnecessary parenthesis =(
Example #1
Entry line
When the brackets are present (unneccesary or not), when the cursor is on a bracket it would be useful to highlight both brackets - and the text within - to make it easier to find the other bracket and ensure the scope of the bracketed part matches your intentions.
Stephen Lewkowicz (G1CMZ)
08-26-2016, 06:44 PM
Is important to highlight, when the entry line allow it. in this case. How I highlight the subparts in the entry line?
08-27-2016, 04:21 AM
(08-26-2016 06:44 PM)compsystems Wrote:  Is important to highlight, when the entry line allow it. in this case. How I highlight the subparts in the entry line?
There are two ways:
(1) Use the touch-screen. Touch one end of the subpart that you wish to highlight, and hold your finger down for more than one second. This sets the "Begin" anchor. Now drag your finger to the end of the desired subpart and release. It is now highlighted.
(2) Move the cursor to the beginning of the desired subpart using either the cursor key or by tapping the screen. Press the Copy key and notice its soft menu. Tap the Begin button to drop the anchor there. Now move the cursor to the end of the subpart and tap the End button. It is now highlighted. To adjust the selection, move the cursor and press either Begin or End again.
<0|ɸ|0>
-Joe-
