Strange HP-31E Function
10-16-2016, 01:35 AM
I am not sure how to describe this, but I have a 31E that works like a currency adder. In other words:
enter 999 and the calculator interprets this as 9.99 no matter what I enter, the decimal is fixed one place from the left. However, if I multiply the value, the decimal place will shift to the right and the commas appear where they are supposed to. If I enter a value using scientific notation, the calculator displays the decimal correctly (when in Fixed mode) It passes the self test. My other 31E does not function like this. Ideas? |
10-16-2016, 03:52 AM
RE: Strange HP-31E Function
(10-16-2016 01:35 AM)aj04062 Wrote: Ideas? Does it pass the self test? I had a wacky 38e that did something similarly weird and it failed the self test. -katie |
10-16-2016, 10:26 AM
(10-16-2016 01:35 AM)aj04062 Wrote: Ideas? This is very likely a ROM bit error, which can result in strange unpredictible behaviour. I own a HP-25C, which couldn't calculate trigonometric functions correctly until I discovered a single errouneous bit in one of its ROM chips. Bernhard That's one small step for a man - one giant leap for mankind. |
10-16-2016, 02:55 PM
(10-16-2016 10:26 AM)PANAMATIK Wrote:(10-16-2016 01:35 AM)aj04062 Wrote: Ideas? I agree and I'm pretty sure that the Spice self test does a checksum of the ROM, so it should fail on AJ's 31E. -katie |
10-16-2016, 05:15 PM
(10-16-2016 02:55 PM)Katie Wasserman Wrote: I agree and I'm pretty sure that the Spice self test does a checksum of the ROM, so it should fail on AJ's 31E. As the 31E passes the selftest, I'm not longer sure about the ROM bit error theory. Perhaps it is a fault of some register in the arithmetik logic unit. For test purpose and if it is a solderless version, the 40-pin chip can be easily replaced by one from another spice model. Bernhard That's one small step for a man - one giant leap for mankind. |
10-16-2016, 10:02 PM
(This post was last modified: 10-16-2016 10:04 PM by aj04062.)
A bit more "functionality".
After charging all night (batteries were almost out), it seems to behave a bit more normal. I thought that might be the cure: undercharged battery. However, it still does it, but now I can force it out if it doesn't start up working correctly (sometimes it is fine). All I did was enter a value with a decimal, clear then re-enter. The second entry displays correctly. I have some dead 31's. Maybe I swap the chip to see if it is gone for good. |
