Problems with HPPrime Virtual Calculator
01-14-2017, 02:24 AM (This post was last modified: 01-14-2017 12:34 PM by compsystems.)
1: The simulator (version 2016_12_08) sometimes holds the [.], When typed from a QWERTY keyboard THE KEY [./:].
Please try Typing quickly f (x): = x / 2
2: In Spanish, the first menu, hide titlebar is in another language, Should be (ocultar barra de titulo)
2.1: The second menu, can be written more complete REINI. -> REINICIAR
01-14-2017, 11:50 AM (This post was last modified: 01-14-2017 11:51 AM by DrD.)
RE: Problems with HPPrime Virtual Calculator
You are talking about the [CAS] side, right?
Does pasting it to the command line count as typing it in quickly?
I'm not seeing this problem here (yet), r11266, win7, english, emulator.
-Dale-
01-14-2017, 12:33 PM (This post was last modified: 01-15-2017 02:30 AM by compsystems.)
Yes, CAS MODE and typing only, not paste expressions
I do not know if the following is also a failure.
[CTRL-PC](hold)+[SHIFT-PC](hold) then drop [CTRL-PC] The SHIFT key on the virtual keyboard is retained
01-14-2017, 03:45 PM
This keyboard problem, I from time to time have it, too. On my german keyboard there is an AltGr-key for typing [] or{}-brackets and sometimes the virtual shift key stays selected, can only be altered by restarting the prime. Today I retried and it worked. So I will have to try to make it reproducable.
Arno
