Is it possible ? AKA Request for Tables
02-25-2014, 12:14 AM
(This post was last modified: 05-27-2014 07:52 PM by Dave Hicks.)
Is it possible:
- to put tables in posts ? Can you add this possibility ? - tp have PPL syntax highlight ? Patrice “Everything should be made as simple as possible, but no simpler.” Albert Einstein |
02-25-2014, 01:28 AM
RE: Is it possible ?
(02-25-2014 12:14 AM)patrice Wrote: Is it possible: Did you see this thread? -katie |
02-27-2014, 10:13 AM
(02-25-2014 01:28 AM)Katie Wasserman Wrote:I was thinking of tables with borders around cells.(02-25-2014 12:14 AM)patrice Wrote: Is it possible: There was a second question in first post. Patrice “Everything should be made as simple as possible, but no simpler.” Albert Einstein |
03-02-2014, 04:21 PM
(This post was last modified: 03-02-2014 04:23 PM by Katie Wasserman.)
(02-27-2014 10:13 AM)patrice Wrote:(02-25-2014 01:28 AM)Katie Wasserman Wrote: Did you see this thread?I was thinking of tables with borders around cells. Yes, with LaTex you make bordered tables but you need to take care of the horizontal lines manually, it's easy. Take a look at my example below: \begin{array}{|c|c|} \hline ASCII & Character \\\hline 65 & A \\\hline 66 & B \\\hline 67 & C \\\hline \end{array} Quote:There was a second question in first post. I don't know what PPL is? [/quote] -katie |
03-02-2014, 04:50 PM
(This post was last modified: 03-02-2014 05:03 PM by patrice.)
(03-02-2014 04:21 PM)Katie Wasserman Wrote:[/quote](02-27-2014 10:13 AM)patrice Wrote: I was thinking of tables with borders around cells.Yes, with LaTex you make bordered tables but you need to take care of the horizontal lines manually, it's easy. Take a look at my example below: Thank you PPL is Prime Programming Language Patrice “Everything should be made as simple as possible, but no simpler.” Albert Einstein |
03-02-2014, 05:45 PM
Quote:PPL is Prime Programming Language I don't know anything about the Prime, so I have no idea how you'd want to highlight/format code but I'm sure that LaTex offers something that would allow you to manually highlight what you want. As far as a special PPL mode on this forum, that's entirely up to Dave. But I doubt that he'd ever want to write special code to handle any one language. -katie |
