Contradiction between CAS and Home
07-09-2017, 10:12 AM
In CAS mode if I type
(1-e^(-1/2))/(1-e^-2) the result is (e^(1/2))^3/((e^(1/2))^3+(e^(1/2))^2+(e^(1/2))+1) wich is 0.174326466693 In home mode if I type the same (1-e^(-1/2))/(1-e^-2) the result is 0.455054233923 that is the result I was looking for. How can this be possible? |
07-09-2017, 10:39 AM
RE: Contradiction between CAS and Home
(07-09-2017 10:12 AM)COB160 Wrote: In CAS mode if I type I get 0.455... in both modes. Tom L Cui bono? |
07-09-2017, 10:46 AM
(07-09-2017 10:39 AM)toml_12953 Wrote:(07-09-2017 10:12 AM)COB160 Wrote: In CAS mode if I type Type (1-e^(-1/2))/(1-e^-2) in CAS mode click enter and u will get (e^(1/2))^3/((e^(1/2))^3+(e^(1/2))^2+(e^(1/2))+1), then go to home-menu-get from CAS-enter to obtain the numerical value of the result |
07-09-2017, 12:41 PM
If the expression is entered in CAS , then use [Shift][Enter], the approximate value returned shows up with the same value as returned when entered in HOME, (on my emulator).
07-09-2017, 12:52 PM
RE: Contradiction between CAS and Home | |||
07-10-2017, 07:00 AM
I was not able to reproduce the error either. All I get is 0.455054233923 every way I try.
07-10-2017, 12:42 PM
07-10-2017, 06:10 PM
COB160: What firmware version are you using?
<0|ɸ|0> -Joe- |
07-10-2017, 08:05 PM
07-10-2017, 09:51 PM
update your firmware
07-10-2017, 10:22 PM
07-10-2017, 11:52 PM
(07-10-2017 08:05 PM)COB160 Wrote:(07-10-2017 06:10 PM)Joe Horn Wrote: COB160: What firmware version are you using?I don know Press Home, Help, Tree (soft key), up-cursor, Enter. What "Software Version" is shown? <0|ɸ|0> -Joe- |
07-11-2017, 07:13 AM
(07-10-2017 11:52 PM)Joe Horn Wrote:(07-10-2017 08:05 PM)COB160 Wrote: I don know It is written: Software version: 2015 6 17 (8151) Hardware version: C CAS Version:1.1.2-11 Serial Number... Operating System: V0.041.558 |
07-11-2017, 07:48 AM
(07-11-2017 07:13 AM)COB160 Wrote:(07-10-2017 11:52 PM)Joe Horn Wrote: Press Home, Help, Tree (soft key), up-cursor, Enter. What "Software Version" is shown? I downloaded HP Connectivity Kit for Mac OS, but I cannot upgrade the calculator... I have read that if the version firmware I have is too old, I had to upgrade the calculator from windows. |
07-11-2017, 07:49 AM
If I have lines on the screen when i scroll history data, could the upgrade fix it?
07-11-2017, 12:44 PM
(This post was last modified: 07-11-2017 12:45 PM by COB160.)
