HP41cv buzzer problem
07-13-2017, 12:41 PM
just to request of your help to try to understand why the buzzer does not work in my HP41CV halfnut (rounded display corners) I opened it to repair the back screw holes area and desoldered the buzzer (from the extreme soldered to the calculator board), which is glued to the back cover. When soldered back in place, there is no answer to beep order. I changed the buzzer with another one taken from a board for parts...no answer. It can be heard a continuous and very very very low buzz when the calculator is "on" Thanks in advance and kind regards Ignacio |
07-13-2017, 01:13 PM
RE: HP41cv buzzer problem
(07-13-2017 12:41 PM)isanchez Wrote: Hi, Is it polarized? Have you tried reversing it? Tom L Cui bono? |
07-13-2017, 07:55 PM
These piezoelectric transducers are not polarized, any more than a speaker is. If you reverse the connections, the output will simply be out of phase, which will have no effect on the sound in this case.
http://WilsonMinesCo.com (Lots of HP-41 links at the bottom of the links page, at http://wilsonminesco.com/links.html#hp41 ) |
User(s) browsing this thread:
