Finding Min/Max of a function for HP-67
03-10-2014, 05:48 PM
finding the minimmum/maximum of a function using Newton's method.
Memory Map
R0 = tolerance
R1 = x
R2 = h
R3 = f(x), f''(x)
R4 = f(x+h)
R5 = f(x-h)
HP-67 Implementation
1 LBL A
2 STO 1     # store guess for optimum x
3 X<>Y
4 STO 0     # store tolerance
5 LBL 0
6 RCL 1     # display current guess for optimum x
7 PAUSE
8 ABS
9 1
10 +
11 EEX
12 CHS
13 3
14 *
15 STO 2     # calculate and store h
16 RCL 1
17 GSB E
18 STO 3     # Calculate and store f(x)
19 RCL 1
20 RCL 2
21 +
22 GSB E
23 STO 4     # Calculate and store f(x+h)
24 RCL 1
25 RCL 2
26 -
27 GSB E
28 STO 5     # Calculate and store f(x-h)
29 RCL 4
30 +
31 RCL 3
32 2
33 *
34 -
35 RCL 2
36 X^2
37 /
38 STO 3     # calculate and store f''(x)
39 RCL 4
40 RCL 5
41 -
42 RCL 2
43 /
44 2
45 /         # calculate f'(x)
46 RCL 3
47 /         # calculate diff
48 STO- 1    # x = x - diff
49 ABS
50 RCL 0
51 X<=Y?
52 GTO 0
53 RCL 1
54 RTN
55 LBL E
56 EXP
57 LASTX
58 X^2
59 3
60 *
61 -
62 RTN
Usage
LBL E has the code for the function whose minimum or maximum you seek.
1) Enter the tolerance and press [ENTER].
2) Enter a guess for the minimum/maximum and pres [A].
3) The program pauses showing intermediate values for the refined min/max values. When the program has reached the tolerance level it displays the value of the X for the min/max value.
04-26-2014, 12:30 AM
RE: Finding Min/Max of a function for HP-67
Very nice! Thanks.
05-26-2014, 12:14 PM
Thank you for sharing.
A pity the listings don't come with key codes. This would allow me to copy/paste the programs right into my HP-67/97 emulators for the iPad...
05-26-2014, 10:13 PM (This post was last modified: 05-26-2014 10:31 PM by Thomas Klemm.)
(05-26-2014 12:14 PM)Willy R. Kunz Wrote:  A pity the listings don't come with key codes.
001  31 25 11    LBL A
002     33 01    STO 1       # store guess for optimum x
003     35 52    X<>Y
004     33 00    STO 0       # store tolerance
005  31 25 00    LBL 0
006     34 01    RCL 1       # display current guess for optimum x
007     35 72    PAUSE
008     35 64    ABS
009        01    1
010        61    +
011        43    EEX
012        42    CHS
013        03    3
014        71    *
015     33 02    STO 2       # calculate and store h
016     34 01    RCL 1
017  31 22 15    GSB E
018     33 03    STO 3       # Calculate and store f(x)
019     34 01    RCL 1
020     34 02    RCL 2
021        61    +
022  31 22 15    GSB E
023     33 04    STO 4       # Calculate and store f(x+h)
024     34 01    RCL 1
025     34 02    RCL 2
026        51    -
027  31 22 15    GSB E
028     33 05    STO 5       # Calculate and store f(x-h)
029     34 04    RCL 4
030        61    +
031     34 03    RCL 3
032        02    2
033        71    *
034        51    -
035     34 02    RCL 2
036     32 54    X^2
037        81    /
038     33 03    STO 3       # calculate and store f''(x)
039     34 04    RCL 4
040     34 05    RCL 5
041        51    -
042     34 02    RCL 2
043        81    /
044        02    2
045        81    /           # calculate f'(x)
046     34 03    RCL 3
047        81    /           # calculate diff
048  33 51 01    STO- 1      # x = x - diff
049     35 64    ABS
050     34 00    RCL 0
051     32 71    X<=Y?
052     22 00    GTO 0
053     34 01    RCL 1
054     35 22    RTN
055  31 25 15    LBL E
056     32 52    EXP
057     35 82    LASTX
058     32 54    X^2
059        03    3
060        71    *
061        51    -
062     35 22    RTN
Namir - Nice program
Any reason to take out and use my HP-67 is a good one.
Thanks for that!
06-08-2014, 04:08 PM (This post was last modified: 07-11-2014 01:24 PM by Willy R. Kunz.)
(05-26-2014 10:13 PM)Thomas Klemm Wrote:
001  31 25 11    LBL A
003     35 52    X<>Y
Thanks, Thomas. Very kind of you.
This also prompted me to have a hard look at RPN-67/97's import capabilities. The result being that in the next update the emulators will accept listings without key codes. In fact, you can now enter and edit programs by simply typing calculator function names in the listing area.
All of Namir's programs shown here run without any editing after pasting.
UPDATE:
RPN-67 Pro v2.5 and RPN-97 Pro v1.5 are now available, featuring the new import capabilities.
Also in these updates: for the first time ever, real breakpoints to help you debug your program.
05-21-2016, 10:50 PM
(05-26-2014 10:13 PM)Thomas Klemm Wrote:  [quote='Willy R. Kunz' pid='12139' dateline='1401106474']
Dear Thomas:
I am using HP 67 SD, I got for Tolerance=5x10-4 and a guessing initial number of 9, a final figure of 2,833144107. Is this correct ?
Now some basic questions please:
1- What equation represents steps 55-62? How I entry an equation to be evaluated?
2- From my example 2,833 is a Max. or a min.? How to obtain both if corresponds?
Thank you in advance, Pedro
05-22-2016, 01:11 AM
(05-21-2016 10:50 PM)PedroLeiva Wrote:  1- What equation represents steps 55-62? How I entry an equation to be evaluated?
As usual, you enter f(x) at LBL E. The argument x is expected in the X-register. Here f(x) obviously is ex–3x².
(05-21-2016 10:50 PM)PedroLeiva Wrote:  2- From my example 2,833 is a Max. or a min.? How to obtain both if corresponds?
Since f"(x) is stored in R3, you could simply inpect this value (RCL 3) an see whether it's positive (minimum) or negative (maximum).
Here the function has a minimum at x=2,833147892... (solution of f'(x) = ex–6x = 0).
At ths point f"(x) = ex–6 is 10,998887... > 0, so this is a minimum. The content of R3 should be close to the latter value.
Dieter
05-22-2016, 01:26 AM
Dieter
Dieter
It's more complicated than I imagined. Luckily I made the query. Thank you very much, Peter
05-22-2016, 07:34 PM (This post was last modified: 05-22-2016 07:36 PM by Dieter.)
(05-22-2016 01:26 AM)PedroLeiva Wrote:  It's more complicated than I imagined. Luckily I made the query.
Hmmm... honestly, I do not quite understand the problem.
You simply enter f(x) as a short routine just as you do with any other "classic" HP, be it the 65, the 41, the 67/97 or most others. The argument x can be expected in the X-register, so you simply type what you'd also do in a manual calculation. In this example f(x) is ex–3x², so it's [ex] [LstX] [x²] [3] [x] [–]. This is what you enter at LBL E so that f(x) can be calculated by a simple [E] or GSB E.
Checking for a minimum or maximum is easily done by RCL 3 after the program has finished. If the result is positive it's a minimum, and if it's negative there's a maximum. A value of (or very close to) zero would indicate a possible inflection point, but this should not happen as the program divides by R3 so that it would have stopped with an error before.
You could add these lines:
053  RCL 3
054  ENTER
055  ABS
056  /
057  CHS
058  RCL 1
059  RTN
This calculates –sign(f"(x)). So after the program has finished, a simple X<>Y will show –1 (minimum) or +1 (maximum).
Dieter
05-22-2016, 10:35 PM
Dieter
[/quote]
The point is that in the original post of this program was no explanation about how to determine Max. or min. (or I did not realize).
From the two options for cheking, I prefer: x<>y (+1, -1), for Max. & min., respectively. This one is more intuitive (+ is related to Max.), the other procedure is inverse.
Thank you for clarifying this math issue, and modifying the program
Pedro
05-23-2016, 01:08 PM
(05-22-2016 10:35 PM)PedroLeiva Wrote:  The point is that in the original post of this program was no explanation about how to determine Max. or min. (or I did not realize).
The program implements a simple Newton iteration to find the zeroes of the derivative f'(x). In a minimum or maximum f'(x) must be zero, and this is what the program finds. It evaluates x_new = x – f'(x) / f"(x).
(05-22-2016 10:35 PM)PedroLeiva Wrote:  From the two options for cheking, I prefer: x<>y (+1, -1), for Max. & min., respectively.
This is what the proposed code does. It returns +1 for a maximum and –1 for a minimum.
Dieter
05-23-2016, 07:37 PM
Examples:
Equation (began step 061) ex–3x²
Tolerance= 1x10-5
Initial guess: 9……………X= 2,83314411………..min…………..Y= -7,08129358
Initial guess: 0,1…………X= 0,20448151……….Max…………..Y= 1,10145071
For X=0……………………Y= 1
For Y=0……………………X= 0,91
For the original equation, input TOLERANCE [ENTER] 9 [A] you get 2,8331, [x<>y] -1 so you know that is a minimun. Later, [x<>y] [E] you get Y=-7.081 wich is the Y value for the min.
When X=0 [E] you get Y=1, that is to say intercept
The value of X when Y=0 was solved by iteraction
Follow the same procedure for the Maximun
Pedro
05-23-2016, 08:00 PM
001  31 25 11    LBL A
003     35 52    X<>Y
005  31 25 00    LBL 0
007     35 72    PAUSE
008     35 64    ABS
009        01    1
010        61    +
011        43    EEX
012        42    CHS
013        03    3
014        71    *
016     34 01    RCL 1
017  31 22 15    GSB E
019     34 01    RCL 1
020     34 02    RCL 2
021        61    +
022  31 22 15    GSB E
024     34 01    RCL 1
025     34 02    RCL 2
026        51    -
027  31 22 15    GSB E
029     34 04    RCL 4
030        61    +
031     34 03    RCL 3
032        02    2
033        71    *
034        51    -
035     34 02    RCL 2
036     32 54    X^2
037        81    /
039     34 04    RCL 4
040     34 05    RCL 5
041        51    -
042     34 02    RCL 2
043        81    /
044        02    2
046     34 03    RCL 3
049     35 64    ABS
050     34 00    RCL 0
051     32 71    X<=Y?
052     22 00    GTO 0
053     34 01    RCL 1
054     35 22    RTN
055  31 25 15    LBL E
056     32 52    EXP
057     35 82    LASTX
058     32 54    X^2
059        03    3
060        71    *
061        51    -
062     35 22    RTN
Thanks Thomas! I was able to copy and paste to my iPhone's RPN-67 SD and it works like a charm!
Bob
05-24-2016, 06:47 AM
I found a pretty good article about the concept at
http://www.themathpage.com/acalc/max.htm
It helped me to understand what's happening with this program.
Bob
05-28-2016, 08:09 PM
Bob
05-28-2016, 09:43 PM
(05-28-2016 08:09 PM)bshoring Wrote:  I found a pretty good article about the concept at
Excellent webpage, also for the others 14th. lessons. Thank´s for sharing
Pedro
User(s) browsing this thread: 5 Guest(s)
