Classic, Woodstock and Spice Emulators
06-10-2016, 07:24 PM
Recently I released an HP-67 emulator for Windows, which is discussed in this thread
Now I released many more microcode emulators for the Classic models, complete Woodstock models and complete Spice models. You can download them for free. Classic Woodstock Spice There is no installation necessary except the optional 7-Segment font. The manual is part of the HP-67 download. If anybody will sell an HP-70 to me, I will be interested for extracting the microcode, which nobody has done yet, therefore this emulator is missing. Bernhard That's one small step for a man - one giant leap for mankind. |
06-10-2016, 09:40 PM
RE: Classic, Woodstock and Spice Emulators | |||
06-10-2016, 09:53 PM
(06-10-2016 09:40 PM)fhub Wrote:(06-10-2016 07:24 PM)PANAMATIK Wrote: Now I released many more microcode emulators for the Classic models, complete Woodstock models and complete Spice models.A nice collection, many thanks! Same problem as Franz; others I tried seemed OK. --Bob Prosperi |
06-10-2016, 09:54 PM
(This post was last modified: 06-10-2016 09:56 PM by PANAMATIK.)
(06-10-2016 09:40 PM)fhub Wrote: Just an info: the file HP32Emulator.zip is damaged, i.e. the HP-32E can't be extracted. OK, if more than one have the same problem, I have to upload again. Try again in 10 minutes. Bernhard That's one small step for a man - one giant leap for mankind. |
06-10-2016, 09:55 PM
(06-10-2016 07:24 PM)PANAMATIK Wrote: Recently I released an HP-67 emulator for Windows, which is discussed in this thread After I had success to ask Alejandro to come to the Allschwil meeting, I now try it with you. How about joining us, giving a talk on your projects? |
(06-10-2016 09:54 PM)PANAMATIK Wrote:(06-10-2016 09:40 PM)fhub Wrote: Just an info: the file HP32Emulator.zip is damaged, i.e. the HP-32E can't be extracted. Just confirmed once again. I can download and send you the file I get if that could help. --Bob Prosperi |
06-10-2016, 10:04 PM
Now the HP32E download works again!
06-10-2016, 10:16 PM
(06-10-2016 10:04 PM)fhub Wrote: Now the HP32E download works again! Yes, but the 33 Link is no longer there. Not complaining Bernhard, just FYI --Bob Prosperi |
06-10-2016, 10:21 PM
Bernhard,
Fantastic - thinks for making these available. Just one little question. I'm playing around with the HP25. I see that there are three jpeg files. How do I switch between them? Thanks, Bill Smithville, NJ |
06-10-2016, 11:21 PM
(06-10-2016 10:21 PM)Bill (Smithville NJ) Wrote: Bernhard, Sorry, the manual is not yet updated for every detail. You can switch by renaming one of them to "woodstock.bmp". You can also select an image of your own, if it has proper aspect ratio. For Classic models the filename must be "Classic.bmp" and for Spice models ..... try by yourself Bernhard That's one small step for a man - one giant leap for mankind. |
06-10-2016, 11:28 PM
(06-10-2016 10:16 PM)rprosperi Wrote:(06-10-2016 10:04 PM)fhub Wrote: Now the HP32E download works again! Thanks Bob for this info. Link is reestablished! Bernhard That's one small step for a man - one giant leap for mankind. |
06-10-2016, 11:40 PM
(06-10-2016 11:21 PM)PANAMATIK Wrote: Sorry, the manual is not yet updated for every detail. You can switch by renaming one of them to "woodstock.bmp". You can also select an image of your own, if it has proper aspect ratio. For Classic models the filename must be "Classic.bmp" and for Spice models ..... try by yourself Just tried it and it works great!! Thanks, Bill Smithville, NJ |
06-12-2016, 01:47 PM
(This post was last modified: 06-12-2016 01:51 PM by Marcus von Cube.)
I tried to run your emulators under OSX, so far without success:
Any ideas? Edit: BTW, your TTF will not properly install under OSX. I did an import into FontForge and an export to TTF. This results in a workable font file (attached). Marcus von Cube Wehrheim, Germany http://www.mvcsys.de http://wp34s.sf.net http://mvcsys.de/doc/basic-compare.html |
06-12-2016, 04:43 PM
So far I tried the HP45 emulator. Works fine under ubuntu 14.04 and wine.
Thanks for making these available! |
06-12-2016, 05:15 PM
(06-12-2016 04:43 PM)Harald Wrote: So far I tried the HP45 emulator. Works fine under ubuntu 14.04 and wine. I have no influence on things, that happen with virtual machines. All emulators are C# .NET 3.5 applications. But don't worry if it does not work on your machine. I will release all emulators also as native ubuntu versions soon. Just need some time. Bernhard That's one small step for a man - one giant leap for mankind. |
06-12-2016, 05:16 PM
(06-12-2016 04:43 PM)Harald Wrote: So far I tried the HP45 emulator. Works fine under ubuntu 14.04 and wine. I just tried the HP-25 on a Raspberry PI 3 running Ubuntu Mate with Mono and it worked fine with the default bmp. But when I tried larger bmp's, the key presses were off. - picture of calculator looked good, but the keypress was still mapped to the original size. Probably something to do with how mono is handling the scaling. I do get a warning message when started with Mono: WARNING: The runtime version supported by this application is unavailable. Using default runtime: v4.0.30319. After warning, it does run and seems fine in the default bmp size. Bill Smithville, NJ |
06-12-2016, 07:35 PM
(06-12-2016 05:15 PM)PANAMATIK Wrote:(06-12-2016 04:43 PM)Harald Wrote: So far I tried the HP45 emulator. Works fine under ubuntu 14.04 and wine. They all seem to work fine. So from my point of view there is no need for a linux version. But where is the HP65? Do I need to send you parcel again? Regards, Harald |
06-12-2016, 09:11 PM
(This post was last modified: 06-12-2016 09:12 PM by PANAMATIK.)
(06-12-2016 07:35 PM)Harald Wrote: They all seem to work fine. So from my point of view there is no need for a linux version. Fortunately I acquired an HP-65 recently and I promise an emulation will be available soon, it just needs some more research. It is not running yet, but I clearly see the way to go. Obviously you didn't have problems with virtually running the emulators, but others seem to have. Bernhard That's one small step for a man - one giant leap for mankind. |
06-12-2016, 09:17 PM
Bernhard,
I notice that the active area for the keypress on the HP-25 is too high. It does not surround the key equaly on all side. This isn't too big a problem when using a mouse, but does create key press errors on a tablet using touch. (Probably due to my fat fingers). How difficult would it be to center the active area around the key? Thanks, Bill Smithville, NJ |
06-12-2016, 09:59 PM
(06-12-2016 09:17 PM)Bill (Smithville NJ) Wrote: Bernhard, I will provide a more general solution, which allows you to adjust the active area also for all possible user images including different aspect ratios. The next version will read a file with key positions, that you can define. I will release the versions tomorrow. Thank you for your feedback and any suggestions. Bernhard That's one small step for a man - one giant leap for mankind. |
