WP 34S --> WP 31S
03-09-2014, 10:21 AM
Post: #181
RE: WP 34S --> WP 31S
Software-wise, there are just two challenges left: the implementation of the reduced number of general purpose numbered registers and the fully fledged UNDO. Looks like we can hang our washing at the target line ... Wink
d:-)
03-11-2014, 07:45 AM (This post was last modified: 03-11-2014 07:46 AM by walter b.)
Post: #182
RE: WP 34S --> WP 31S (more black art)
We're going to change the layout a bit, mainly for space and grouping reasons:
That will become v1.2 of the WP 31S. And UNDO is making progress, too.
d:-)
03-11-2014, 11:06 AM
Post: #183
(03-11-2014 07:45 AM)walter b Wrote:  We're going to change the layout a bit, mainly for space and grouping reasons:
d:-)
Has x! and PROB been combined into DISTR?
03-11-2014, 11:52 AM
Post: #184
UNDO is more interesting -- the complete reversal of the last successful command. No previous calculator I know of has had this. This isn't just reverting the stack like the RPL UNDO, it reverts everything.
Change a mode setting? Undone.
Store something to a register? Undone.
Pauli
03-11-2014, 11:55 AM
Post: #185
(03-11-2014 11:06 AM)Harald Wrote:  Has x! and PROB been combined into DISTR?
Almost Wink
DISTR contains exclusively the ten probability DISTRibutions provided, while all the other STATistical and probability functions featured went into STAT.
d:-)
03-11-2014, 03:20 PM
Post: #186
Gene: I would like to suggest another reconsideration of using two spots on the keyboard for % and Delta%. :-)
Plea? What about x! in place of Delta% at least?
03-11-2014, 04:35 PM
Post: #187
(03-11-2014 03:20 PM)Gene Wrote:  I would like to suggest another reconsideration of using two spots on the keyboard for % and Delta%. :-)
Being at that topic (once again), I'd vote for removing % from a scientific while Δ% makes a lot more sense here IMHO. How about x! in place of % ?
d:-)
03-11-2014, 08:13 PM
Post: #188
d:-)
I'd rather have x! on a scientific than either % of Delta%. How about a poll? I'm certainly willing to live with the concensus. :-)
03-11-2014, 09:03 PM
Post: #189
(03-11-2014 08:13 PM)Gene Wrote:  How about a poll? I'm certainly willing to live with the concensus. :-)
Certainly! I love polls ... Smile
03-25-2014, 10:12 AM
Post: #190
Taking the results of the poll (found elsewhere on this forum) and some further thinking, this is how the WP 31S is going to look:
Our SW department is just finalizing work to make it happen.
d:-)
03-25-2014, 05:52 PM (This post was last modified: 03-26-2014 05:22 PM by Jeff O..)
Post: #191
(03-25-2014 10:12 AM)walter b Wrote:  Taking the results of the poll (found elsewhere on this forum) and some further thinking, this is how the WP 31S is going to look...
That is of course a rendition using a 20b as a base. While it is more attractive, I think all agree that the 30b is far superior.
Below are two renditions of just the overlay, which could be used on a 20b or 30b. I created this as an svg file, based on a 34s overlay I got sometime ago. I believe Eric "cuts" from svg files, although I do not know if my file is directly "cuttable" or would require more work. Eric is certainly welcome to it if he is interested in producing 31S overlays.
[Image: attachment.php?aid=411]
[Image: attachment.php?aid=412]
-edited to change the shift key per Walter's request. Added second version with alternate division key legend.
2nd edit, revised greek letters.
Dave - My mind is going - I can feel it.
03-25-2014, 06:21 PM
Post: #192
(03-25-2014 05:52 PM)Jeff O. Wrote:  Below is a rendition of just the overlay, which could be used on a 20b or 30b.
Thanks Jeff,
Could you mention what exact width this image needs to be printed to match the physical device?
-Jonathan
03-25-2014, 06:59 PM (This post was last modified: 03-25-2014 07:48 PM by walter b.)
Post: #193
(03-25-2014 05:52 PM)Jeff O. Wrote:  Below is a rendition of just the overlay, which could be used on a 20b or 30b. I created this as an svg file, based on a 34s overlay I got sometime ago.
I'm not very keen on rewriting the whole manual, so would you please modify the prefix key to match the 'more attractive' rendition. TIA.
d:-/
Addendum: Just found also the division / was changed to a less differentiable symbol (looking like + in some distance). And µ and γ are not adjusted properly in vertical direction compared to the other Greek letters. Also the Greek font doesn't match the Latin one, and even Latin lower case letters don't match the capitals. Rats, why does one spend hours for a proper design if anybody can destroy it in seconds?!? :(
03-26-2014, 01:13 PM
Post: #194
(03-25-2014 06:59 PM)walter b Wrote:  ...would you please modify the prefix key to match the 'more attractive' rendition...
Revised my original post to address the above concerns.
(03-25-2014 06:59 PM)walter b Wrote:  And µ and γ are not adjusted properly in vertical direction compared to the other Greek letters. Also the Greek font doesn't match the Latin one, and even Latin lower case letters don't match the capitals. Rats, why does one spend hours for a proper design if anybody can destroy it in seconds?!? Sad
I was not competely happy with those symbols either, but wanted to present something. I'll see if I can improve.
03-26-2014, 01:20 PM (This post was last modified: 03-26-2014 01:20 PM by Jeff O..)
Post: #195
(03-25-2014 06:21 PM)Jonathan Cameron Wrote:  Thanks Jeff,
-Jonathan
Johnathan,
The original file from which I was working stated to "scale from 2.660" to 2.670" wide". But I don't know if that left room for trimming in the cutting process. You might need to experiment. Also, the image presented is a much reduced version. If you want to print, it might be preferable to print from the unreduced file, which I can provide if desired.
03-26-2014, 01:40 PM
Post: #196
UNDO FROM WP 31S TO WP 34S?
(03-11-2014 11:52 AM)Paul Dale Wrote:  UNDO is more interesting -- the complete reversal of the last successful command. No previous calculator I know of has had this. This isn't just reverting the stack like the RPL UNDO, it reverts everything.
Knowing that the WP 34S is finished and everything: This sounds so interesting!
Any chance of seeing it there?
The same question goes for the WP 43S naturally...
a.
03-26-2014, 02:14 PM
Post: #197
(03-26-2014 01:20 PM)Jeff O. Wrote:
(03-25-2014 06:21 PM)Jonathan Cameron Wrote:  Could you mention what exact width this image needs to be printed to match the physical device?
Johnathan,
Thanks. I will probably go with the "official" emulator image and experiment, edit, etc, to get something usable. I just thought if you are going to provide an overlay, you should tell what size to print it!
-Jonahtan
03-26-2014, 02:20 PM
Post: #198
I assume you mean the WP-31s. It should be available very soon. Walter has supplied the "final" keyboard layout image (for the emulators) and Sanjeev has updated the key mapping. We are working on a couple minor issues. Once those are resolved, we will update the flash image and emulator on the sourceforge site. We will post here when the updates are available.
-Jonathan
03-26-2014, 02:22 PM
Post: #199
It's all a matter of space. The WP 31S is stripped down from the WP 34S - in particular, it's not user-programmable and supports far less registers. This gave us 'lots' Wink of free space we used for implementing UNDO (which in fact recalls a copy of all registers). There is definitly NO chance anybody will see this in the WP 34S for the reasons stated. Sorry.
For the WP 43S, OTOH, wishing may still help. I'd guess, however, that a confirmed (!) deletion of all registers won't be made revertible, nor will a confirmed deletion of a lengthy program. As stated above it's all a matter of space, and I think most users will prefer an increase of accessible data and program storage area over an increase of (inaccessible) backup space, especially on a calculator offering some I/O capabilities. Just my 20m€.
d:-)
03-26-2014, 02:32 PM
Post: #200
(03-26-2014 01:13 PM)Jeff O. Wrote:  Revised my original post ...
Thanks, Jeff, looks better now. Smile
Looking forward to further progress. Since those letters are all "handmade in Germany" I can't recommend a font where you can steal them from ... Undecided
d:-)
