Green background with GetKey Problem!?
03-17-2017, 03:46 PM
RE: How make a green Background by a Choose Funktion
okay, what is with this Solution. But i don't why the Program leave the Repeat-Until Funktion when i press 1, repeat1.. or 2, repeat 2.. or 3 and repeat 3..? EXPORT NewInput() BEGIN RECT_P(0,0,320,220,RGB(0,255,0)); TEXTOUT_P("F L U G N A V I G A T I O N",31,20,7,RGB(255,255,255)); TEXTOUT_P("Press 1 für: ICAO",70,70); TEXTOUT_P("Press 2 für: POSITION",70,100); TEXTOUT_P("Press 3 für: FLUGSTRECKE",70,130); TEXTOUT_P("Press Del für Abbruch",70,160); REPEAT K:=GETKEY; IF K==42 THEN PRINT("ICAO"); END; //KEY Test IF K==43 THEN PRINT("POSITION"); END; //KEY TEST IF K==44 THEN PRINT("FLUGSTRECKE"); END; //KEY TEST UNTIL K==19; STARTVIEW(-1); END; |
03-17-2017, 04:22 PM
RE: Green background with GetKey Problem!?
Rethink UNTIL K==19; line
My website: erwin.ried.cl |
03-17-2017, 04:31 PM
What do you mean?
03-17-2017, 04:48 PM
Do you mean
UNTIL K==19 or K==42 or K==43 or K== 44; |
03-17-2017, 06:52 PM
(03-17-2017 04:48 PM)Onieh Wrote: Do you mean That is an option My website: erwin.ried.cl |
03-17-2017, 09:46 PM
And the other one?
