New HP Prime update 2.1.14730
07-17-2023, 06:18 PM
Post: #81
RE: New HP Prime update 2.1.14730
Here is the thread detailing which devices are finding HP Prime Pro, and which aren't.
https://www.hpmuseum.org/forum/thread-20078.html Stephen Lewkowicz (G1CMZ) https://my.numworks.com/python/steveg1cmz |
07-18-2023, 10:15 AM
Post: #82
I have many problems with this update!
08-06-2023, 01:35 PM
(This post was last modified: 08-06-2023 01:52 PM by komame.)
Post: #83
AFilesB crashes for reading more than 10000 bytes if the file is large enough. This causes a reboot instead of displaying "Insufficient memory" or something similar (tested on G1).
For example: AFilesB("bigfile",0,10001); |
09-15-2023, 12:28 PM
Post: #84
Hi Klaas,
It's been a while now and was just wondering if you have an ETA for the Mac update? Even a rough ETA (eg this year or 1st half next year). TIA, dmh (04-24-2023 07:02 AM)KlaasKuperus Wrote: Hi all, Calculator Clique on YouTube |
09-24-2023, 10:10 AM
(This post was last modified: 09-24-2023 10:14 AM by StephenG1CMZ.)
Post: #85
(05-01-2023 11:18 AM)KlaasKuperus Wrote:(04-30-2023 01:12 PM)Dirk.nl Wrote: Klaas, I know that anticipated dates can slip, and "summer" was just a target... But as my calendar tells me summer is now over, I wonder when we can now look forward to an update (or did I miss an announcement?) (I'm interested in the Android app in addition to the actual calculator - Hoping an update is still planned) Stephen Lewkowicz (G1CMZ) https://my.numworks.com/python/steveg1cmz |
09-24-2023, 09:08 PM
Post: #86
(08-06-2023 01:35 PM)komame Wrote: AFilesB crashes for reading more than 10000 bytes if the file is large enough. This causes a reboot instead of displaying "Insufficient memory" or something similar (tested on G1). Piotr, thanks for posting — and for filing a bug report on the bug tracking site I’ve set up. The bug got fixed! |
09-25-2023, 01:56 PM
Post: #87
(09-24-2023 09:08 PM)jte Wrote:(08-06-2023 01:35 PM)komame Wrote: AFilesB crashes for reading more than 10000 bytes if the file is large enough. This causes a reboot instead of displaying "Insufficient memory" or something similar (tested on G1). Thanks! So it's time to fill up the bug tracker with new bugs! P. |
10-31-2023, 02:12 AM
Post: #88
(05-14-2023 12:52 PM)Pavel OK1DNZ Wrote: CK and HP Prime G1 calculator (HW version A, CAS v. 1.5.0 & OS v. V0.050.640) updated to the latest version 22.1.14730 (023 04 13). The CK sees G1 calculator connected via USB cable. When I click on calculator name in CK to display all calc. items, the calculator reboots immediately. The same response on W10 and W11; Firewall disabled. No such issue with updated PC HP Prime or Android HP Prime Pro (2.1.14594 (2021 05 14)). Hope next SW release fix this issue (connectivity to HP Prime G1, HW v. A under W10 & W11) soon. Thank you. I get this same behaviour (same calculator, same versions), physical calculator reboots when I open it in CK. I reset my calculator completely and it works fine in CK (I can open it). Then (in CK) I simply copied the spreadsheet and added a few very simple formulas into the new sheet, saved it to write it to the calculator, and backed up the calculator. After disconnecting & reconnecting, this reboot behaviour started happening and also the backup option is missing from the right-click menu. I reset the calculator again, and this time copied and populated the (copied) spreadsheet on the physical calculator, and I can now disconnect/reconnect and open my calculator within CK. Now though I'm unable to connect the app to CK where it was connecting before, and the app can still see the server name for CK. I don't know how reproduceable all this is, I think last time I got the app to connect after I uninstalled/reinstalled CK and updated it. That did *not* fix the calc rebooting when you open it in CK though. It's the first time in a while that I picked up the calculator, started from a blank slate and had all these issues in minutes, I don't think the dev team would have to take much time to try to reproduce... |
01-10-2024, 05:43 PM
(This post was last modified: 01-10-2024 05:45 PM by komame.)
Post: #89
I've noticed recurring problems that arise when I first start CK, then VC, and only after that do I connect G1 via USB cable. In such a scenario, it happens that G1 is detected after a very long time, even 20-30 seconds (but it eventually appears). After launching CK, if I connect G1 first (without starting VC), it appears without any delays. I've never observed these delays when connecting G2.
(10-31-2023 02:12 AM)ebswift Wrote: [...] and also the backup option is missing from the right-click menu. [...] As for the missing "Backup" option in the context menu, you need to expand the item in the tree for the given device, and then after a moment the "Backup" option appears. Piotr |
01-11-2024, 05:59 AM
Post: #90
Bonjour
Encore une fausse joie, à chaque fois que ce post ressurgit, pendant un court instant je crois à une nouvelle mise à jour Hello Another false joy, every time this post resurfaces, for a brief moment I think it's a new update Sorry for my english |
01-11-2024, 03:29 PM
Post: #91
Same!
01-11-2024, 09:04 PM
Post: #92
Who should produce an update? The current licensee?
uuh, what timeline? I want these drugs too. |
01-12-2024, 08:12 AM
Post: #93
RE: New HP Prime update 2.1.14730 | |||
01-12-2024, 12:55 PM
Post: #94
(01-11-2024 05:59 AM)Tyann Wrote: Bonjour A new version announcement would be at the start of a new thread with the version number in it. Any additions to this thread are just old comments (like this one!) Tom L Cui bono? |
User(s) browsing this thread:
